Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: ADATA SE730H -droped and not detected
PostPosted: July 19th, 2023, 11:22
twist the differential signal pairs together (txn with txp and rxn with rxp)
PostPosted: July 19th, 2023, 11:53
I'd just shorten the wires by about 6ft :roll: and try again. Hot snot a sata connector 90 degrees to the usb on top of the dram and wire it up, nice and stable and minimal length.
PostPosted: July 19th, 2023, 15:30
by 6 ft???
those wires are like 2 inches.
But yeah, a simple sata connector borrowed from any hdd pcb would be better than this something that we don't know what is it :)
PostPosted: July 20th, 2023, 3:25
To be frank, the wiring looks terrible. Even if the firmware is functioning properly, it cannot work.
http://flash-matrix.com/
PostPosted: July 20th, 2023, 3:55
pepe wrote:
by 6 ft???
hyperbole Pepe :wink:
PostPosted: July 27th, 2023, 11:55
I am using msata plastic frame to fix SSD so it doesn't hang on those tiny wires.
I've twist cable doesn't help. Drive always come ready, I can upload loader from PC3K SSD tool but none of them will give data access.
PostPosted: July 27th, 2023, 12:28
For SM2258G or 2258H controllers, do not place too much hope on the loader. Based on my experience, only a very small number of public FW versions that use early 3D Micron chips are likely to be supported by 3K SSD.
PostPosted: July 27th, 2023, 12:45
Yes, so that means there is not solution unless a new specific loader appear
PostPosted: August 3rd, 2023, 19:59
Not really. Have you checked for terminal output when you connect it?
PostPosted: August 4th, 2023, 8:50
Thanks. I haven't tried as I didn't know terminal was an option. RX and TX are located one the 2 x 6 holes at the back of the card ?
Users browsing this forum: jcan and 24 guests
