Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rosewood Unable to read rom
PostPosted: July 23rd, 2023, 8:26
terminator2 wrote:
einstein9 wrote:
pepe wrote:
boot terminal is locked, probably...
if so, you will need to use ext programmer
pepe, have a close look @the athached image 1.png 1st red marked line
he is using the old adapter
Thanks einstein9 :-D :good:
Pointing out exact issue. I was of opinion with old terminal adpater I will not be able to adjust signal levels but for basic functions it will work.
But it seems I will have to replace it anyhow.
One last question whether this adapter which is readily available will be fine or I should go for ace one ?
I am using this for over a year no issue at all. ace one was 3 times costly. I think both adapaters use same chipset and are manufactured in china.
Being ace price is high.
