 Post subject: Samsung HS06THB HD interface connection
PostPosted: July 29th, 2023, 5:48
Hi Folks
I have the HD described in the title. It came from a friends old Compaq laptop and I am keen to get the data off for him. I thought I could just take it out of the lappy and place it in a caddy but no. It only has a ribbon cable for connections unlike I have ever seen before. Needless to say it will not connect to any of my caddys. An image of the disk with its connections can be viewed here: https://dstockmicro.com/fr/disques-de-stockage/1004-hs06thb.html
Any ideas what I could use?
Thanks.
 Post subject: Re: Samsung HS06THB HD interface connection
PostPosted: July 30th, 2023, 1:26
Interface Types: IDE ATA 1.8in ZIF
Plenty of adapters usual at the places - amazon, ebay , aliexpress etc
PostPosted: July 30th, 2023, 5:43
Except that it's not 1.8in more like 0.8in. see the attached photo. Maybe it's proprietary, if so there may not be any kind of adapter available.
PostPosted: July 30th, 2023, 6:00
1.8" doesn't refer to the connector - https://en.wikipedia.org/wiki/Zero_insertion_force I can't be bothered to count the pins but at a guess 40 which would be pata.
https://www.amazon.co.uk/External-1-8-I ... 00KZIBJT8/ Should work as should https://www.amazon.co.uk/cigemay-Adapte ... 09QLYH35M/ so should this
PostPosted: July 30th, 2023, 9:01
Thanks for that Lardman. It is indeed have 40 pins. Will probably order one of your suggested adapters in the near future.
Users browsing this forum: Google [Bot] and 50 guests
