 Post subject: ST1000LM035 rosewood clicking after replace many new heads
PostPosted: July 30th, 2023, 17:39
Hi
I tried all preamp available types.
Although main rom moduls without CRC errors I analyzed the rom content.
I found one bit which does not appear in any of the dozens of rom I checked.
When I changed the bit to the value that appears in the others(it's the same in everyone in that family),so no more clicking but there are these errors:
Boot 0x80M
TCC:001F
[LBA=0x00000001][LBA=0x00000001]
RECOV Servo Op=06DF Resp=0005
DSC PASS
RECOV Servo Op=0095 Resp=0005
SIM FileFD=FC000000 ErrorCode=43160080 DiscLBA=0000000000000001 Duration=0000063E ms
RECOV Servo Op=0195 Resp=0005[LBA=0x0000DA01][LBA=0x0000DA01]
SIM FileFD=FC000000 ErrorCode=43160080 DiscLBA=000000000000DA01 Duration=00000048 ms
RECOV Servo Op=0095 Resp=0005[LBA=0x00000406][LBA=0x00000406]
SIM FileFD=FC00320D ErrorCode=43160080 DiscLBA=0000000000000406 Duration=00000047 ms
RECOV Servo Op=0195 Resp=0005[LBA=0x0000DE06][LBA=0x0000DE06]
SIM FileFD=FC00320D ErrorCode=43160080 DiscLBA=000000000000DE06 Duration=00000046 ms
SimError - Remaining in BootFW
Perform a double download without a power cycle.
I checked, these errors are because eight lines within the SAP.
But in these eight lines there are many possibilities.
I will pay for a solution.
 Post subject: Re: ST1000LM035 rosewood clicking after replace many new hea
PostPosted: July 30th, 2023, 23:48
Which bit u changed? u may try Virtual boot MRT
PostPosted: July 31st, 2023, 9:27
MRT virtual output:
TCC:0023
DSC PASS
SIM FileFD=FC000000 ErrorCode=43160080 DiscLBA=0000000000000001 Duration=00000607 ms
---Mrt Loader---
LockCode:0x9288DA10
LockKey:Recv Loader....Redy
Rst 0x80M
T:0x0001 0x0AF0B48E
LED:0x000000BD FAddr:0x00009039
PrgF
PostPosted: August 3rd, 2023, 14:15
I had a similiar case with 4TB hdd ,The issue was the smart a@#@# data recovery technician before me had headmap to 00 00 00 00 04 04 040 04 lol .Disable Media Cache For The Time Being And Try And Also Check Headmap in ROM
PostPosted: August 3rd, 2023, 21:46
Head map are correct.
Drive ID with capacity -1 (8796093022208.00 GB) in this state it is not possible to perform any action so I can't disable Media Cache.
I changed one bit at offset 802F6(SAP 2F6) from 89 to 09 and it stop click but can't ID.
Besides I found that 99% of sap you can take from donor and somehow to get access to the drive only 1% need to be original in this case I have a problem with that 1%.
PostPosted: August 3rd, 2023, 21:55
you drive has rare heads, check if the heads vendor is marked "alternative" instead of "default" in pc3k rom dialog.
very likely your drive is "alternative" and all the donors are "default".
you'd need correct heads vendor for the donor
PostPosted: August 3rd, 2023, 22:42
I don't have pc3k only MRT and sediv can I get vendor information via terminal? (it doesn't appear in the Ctrl + l command).
Is there preamp type in addition to c2 87 82 ?
PostPosted: August 3rd, 2023, 23:13
This "pc3k rom dialog" gives details about rom in boot code?
PostPosted: August 3rd, 2023, 23:26
it works with flash ROM file
PostPosted: August 3rd, 2023, 23:31
Well,
Sys file 0x93 has This And Surely in PC3K We can disable whatever we need to
PostPosted: August 3rd, 2023, 23:34
Well,
Is PC3K Not capable in giving us exact preamp that its reverting to Default and Alternative Like Words
PostPosted: August 3rd, 2023, 23:35
Just find a donor that has this bit.
It is not an easy find though.
You also can use microscope to check the sliders, they will be different on the original and donors that you used.
PostPosted: August 3rd, 2023, 23:36
No, there are only three
But your problem is not the preamp.
PostPosted: August 3rd, 2023, 23:37
Well,
VB Is Not a Solution for Any and Every Issue of Seagate .Whats your experience ,I just updated to Version 218X and i feel MRT Does a Fair Enough Job ,DE Really Needs To Be Update Though Its Too Basic
PostPosted: August 3rd, 2023, 23:38
Sir ,
Whats the problem according to you in this case
PostPosted: August 3rd, 2023, 23:42
Sir ,
I already answered that
your drive has rare heads, check the heads vendor
PostPosted: August 3rd, 2023, 23:47
Jirbun wrote:
MRT virtual output:
TCC:0023
DSC PASS
Change the bit back, the drive won't read any data anyway, only servo.
You can't trick the drive like this unfortunately. You have to have correct heads.
PostPosted: August 4th, 2023, 1:37
Doomer wrote:
Jirbun wrote:
MRT virtual output:
TCC:0023
DSC PASS
Well,
Wise Man Wise Advise Thanks Doomer Sir :please:
PostPosted: August 4th, 2023, 9:20
Doomer wrote:
Jirbun wrote:
MRT virtual output:
TCC:0023
DSC PASS
Change the bit back so "Fail servo" drive clicks with all three preamp types.
PostPosted: August 4th, 2023, 9:27
Here is the rom if you can write it to your donor and turn it on for half a second to see if donor clicks.
If not,then please PM me a quote for donor.
RO orgi.rar [262.68 KiB]
Downloaded 365 times
Users browsing this forum: Google [Bot] and 256 guests
