 Post subject: WD 2TB - Can You help me identify the fault?
PostPosted: August 14th, 2023, 13:31
Can someone help me identify the fault by listening to the sound the hard drive makes?
https://soundcloud.com/adoman11/2tb/s-0 ... al_sharing
 Post subject: Re: WD 2TB - Can You help me identify the fault?
PostPosted: August 14th, 2023, 21:35
Drive can't spin? Most likely cause heads are stuck on the platter.
Diagnosing anything via a sound is stupid.
PostPosted: August 14th, 2023, 22:13
100% heads stuck on platters. If data is important, take it to a pro.
PostPosted: August 15th, 2023, 4:02
You appear to be very unlucky with your drives lately or are these client drives?
PostPosted: August 15th, 2023, 4:07
Thank you for your reply..
PostPosted: August 15th, 2023, 4:08
I'm grateful for your assistance. Thank you!
PostPosted: August 15th, 2023, 4:11
I'm honing my data recovery skills by working on faulty hard drives I have. I'll be opening the drive in a clean environment.
PostPosted: August 22nd, 2023, 14:04
And then? If you have no proper skills to solve the stiction you risk to make everything worse. So if this is a client drive and the data is critical - DON'T DO IT!
You will need special hardware in the next step to prevent to mess up the second level translator and other firmware modules.
Users browsing this forum: Google [Bot], Rendersmith and 51 guests
