 Post subject: Barracuda 7200.9 ST3300622A fw 3.AAJ - VERY RARE !!
PostPosted: August 17th, 2023, 7:02
i need ROM + modules for this drive
Barracuda 7200.9
ST3300622A
fw: 3.AAJ
s/n: 4NFxxxxx
My firmware database:
 Post subject: Re: Barracuda 7200.9 ST3300622A fw 3.AAJ - VERY RARE !!
PostPosted: August 17th, 2023, 8:13
I don't recall Maxtor and Seagate ever collaborating on a drive. Are you sure you can trust the label?
PostPosted: August 17th, 2023, 9:13
There are many Maxtor/Seagate drives out there!
For instance:
https://hddstockroom.com/catalog/maxtor/10169/
https://hddstockroom.com/catalog/maxtor/10252/
ACELab partner
PostPosted: August 17th, 2023, 12:12
Hi Nuno,
the 2nd you've linked seem to be similar, exept for model name and first 3 digits on s/n
Fw version matches!
I guess it would not have the rom i need, even if is similar.
PostPosted: August 17th, 2023, 12:18
Maxtor DiamondMax corresponding to Barracuda 7200
DiamondMax20 -------> 7200.9
DiamondMax21 -------> 7200.10
DiamondMax22 -------> 7200.11
PostPosted: August 17th, 2023, 22:03
Here fw ftp://atxlab.ddns.net/ftp/hdd/sea/res/G ... A_0AA_0B9/
PostPosted: August 18th, 2023, 23:17
Weird, I now vaguely remember them. I think old age is setting in.
PostPosted: August 20th, 2023, 7:32
michael chiklis wrote:
Hi Nuno,
Fw version matches!
I can get it if you want.
ACELab partner
PostPosted: August 20th, 2023, 8:18
Really?
If you can do that, you're really great!
Please, let me know...
Thanks.
PostPosted: August 20th, 2023, 13:58
napalm_atx wrote:
Can SATA firmware be used to recover an IDE drive? :-?
PostPosted: August 20th, 2023, 15:19
Get it in the terminal: Wrong Yuma Chip! :)
PostPosted: August 20th, 2023, 16:32
ISTR that in the early days of SATA, some SATA drives had an IDE MCU with a separate SATA-IDE bridge IC tacked onto the front end. I was wondering whether the SATA version of the OP's drive could have a SATA-IDE bridge embedded within a native IDE MCU. If that were the case, then both drives could use exactly the same firmware.
PostPosted: August 20th, 2023, 16:48
PCB mounted on this drive is 100368182 Rev A (IDE)
The relative sata pcb which probably would work on this drive should be 100355589
P.S.
I don't know if this ide pcb is the original, this drive was tampered by onother DR company before to be sent to me, maybe before that also by a computer shop/customer.
Users browsing this forum: Google [Bot], Rendersmith and 50 guests
