 Post subject: Missing WD ROM
PostPosted: August 23rd, 2023, 12:46
Hi
there a western my passport with pcb 1960 that ROM IC is missing from PCB. is there any chance to recover ROM?
 Post subject: Re: Missing WD ROM
PostPosted: August 23rd, 2023, 12:59
Yes you can.
PostPosted: August 23rd, 2023, 14:16
How? :?:
PostPosted: August 23rd, 2023, 14:32
https://blog.acelab.eu.com/pc-3000-for- ... l-rom.html
PostPosted: August 26th, 2023, 13:49
ddrecovery wrote:
https://blog.acelab.eu.com/pc-3000-for-hdd-building-rom-image-from-sa-data-on-wd-marvell-drives-with-external-rom.html
Thanks but it need ACElab login which I dont have, could you share it here ?
PostPosted: August 27th, 2023, 3:59
AceLab has posted this procedure on youtube:
https://youtu.be/rPqrUewgMJ4?si=qgYgS-3M-l2BKF5H
My firmware database:
PostPosted: August 27th, 2023, 8:24
This method will not work with the OP drive.
The OP drive is FBLITE which requires special technique to generate working ROM.
PostPosted: August 27th, 2023, 9:38
Yep, you're right. 771960 belongs to FbLite family.
I've missed that! :)
This is the right video for this family drive rom recovery (in the video example from acelab, they're working on HubbleLT family):
https://youtu.be/CdH7AHesiRk?si=wHLPi_XtL9s_BxCc
Acelab uses special plugin to find factory settings on surface to generate 4F mod, and it takes long time.
I think that plugin is based on some type of ARCO test.
Users browsing this forum: Rendersmith and 61 guests
