 Post subject: Rosewood ST1000LM035-1RK172 Stays BSY after getting ready
PostPosted: September 1st, 2023, 9:15
This rosewood drive gets ready but goes to BSY as soon as I try to access any sector.
below is terminal output.
(P) SATA Reset
RAW OFF
PASS
Drive AMPS Configuration has been modified from compiled defaults.
Drive must be re-initialized to controller firmware defaults by re-downloading controller firmware
DO NOT SHIP WITHOUT FIRST RE-DOWNLOADING CONTROLLER FIRMWARE OR RESETTING TO DEFAULTS!
(DOS Table) Worst Count: 00000FFA At SU: 0000531D NT: 00000000 OT: 00000020
MSP213
(MC POR Duration): 0000000045
PrgF
PrgF
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
Common path start quit now ProcessRC: 00000000,00000000SkipLen: 00000000ReadContinuous: 0E06D933,00000322UnrecovSectorCount:00D7,0321,0042NumUDEs: 000000D7,00000003,00000321Passed: 00000080,00000140,000002D1Out:
PE  43110081
PrgF
LED:0x000000EE FAddr:0x004E6CE0
I have got all the important modules backedup. Also when I try to write updated 93 in indirect ATA mode it gets bsy and fails.
Kindly advise.
Best Regards,
Murtaza H.
Data Recovery Dubai
 Post subject: Re: Rosewood ST1000LM035-1RK172 Stays BSY after getting read
PostPosted: September 1st, 2023, 13:59
is that the full log? what happens before the SATA Reset?
PostPosted: September 1st, 2023, 15:04
this is the terminal output if I dont press Ctrl+Z for Terminal Prompt.
Boot 0x80M
Tech Unlock Handshake: 0x33EFD0C9
Reply:
QB
Rst 0x80MSrv ETCR init 0x0000
PrgF
(P) SATA Reset
RAW OFF
PASS
MSP213
PrgF
Intel 6G->3G
CSpd= 3Gbps
DSC
Common path start quit now ProcessRC: 00000000,00000000SkipLen: 00000000ReadContinuous: 0E06D933,00000322UnrecovSectorCount:00D9,0321,0042NumUDEs: 000000D9,00000023,00000321Passed: 00000080,00000140,000002D1Out:
PE  43110081
PrgF
And this, If after handshake I press Ctrl + Z for Terminal Prompt.
Boot 0x80M
Tech Unlock Handshake: 0x380EF2B7
Reply:
QB
PrgF
(P) SATA Reset
RAW OFF
PASS
MSP213
PrgF
Intel 6G->3G
CSpd= 3Gbps
DSC
ASCII Diag mode
F3 T>
Input_Command_Error
F3 T>
ASCII Diag mode
F3 T>
Input_Command_Error
F3 T>
ASCII Diag mode
F3 T>
Input_Command_Error
F3 T>
Best Regards,
Murtaza H.
Data Recovery Dubai
PostPosted: September 1st, 2023, 17:48
where did the LED EE disappeared? now it doesn't happen?
PostPosted: September 2nd, 2023, 1:10
It does not show LED EE if I enter the terminal prompt. If I dont press CTRL + Z then it shows LED Error after about every 40 to 50 seconds.
Best Regards,
Murtaza H.
Data Recovery Dubai
PostPosted: September 2nd, 2023, 4:57
ic. Can you post ROM and sysfiles 0_20D, 0_20E (if already read)?
PostPosted: September 2nd, 2023, 5:23
please find attached.
ROM-20D-20E.zip [2.33 MiB]
Downloaded 200 times
Best Regards,
Murtaza H.
Data Recovery Dubai
Users browsing this forum: No registered users and 35 guests
