 Post subject: Samsung 850 Evo - suddenly gave up, any chances left?
PostPosted: September 12th, 2023, 9:11
Hi all,
My machine suddenly wouldn't boot anymore and was stuck at bios stage unless I disconnect this drive.
Using an USB-to SATA cable I can connect it with another machine, but can't even run smartctl:
Also this StarTech USB-SATA adaptor gets kinda hot... but i don't know if this is normal.
[62139.985672] usb 2-3: new SuperSpeed USB device number 9 using xhci_hcd
[62139.998434] usb 2-3: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[62139.998449] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[62139.998456] usb 2-3: Product: SSD 850 EVO 250G
[62139.998461] usb 2-3: Manufacturer: Samsung
[62139.998465] usb 2-3: SerialNumber: 12345678E380
[62140.005101] scsi host3: uas
[62140.005617] scsi 3:0:0:0: Direct-Access     Samsung  SSD 850 EVO 250G 0    PQ: 0 ANSI: 6
[62140.009030] sd 3:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[62140.009146] sd 3:0:0:0: [sdb] Write Protect is off
[62140.009150] sd 3:0:0:0: [sdb] Mode Sense: 43 00 00 00
[62140.009193] sd 3:0:0:0: Attached scsi generic sg1 type 0
[62140.009307] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[62140.009475] sd 3:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
[62140.009479] sd 3:0:0:0: [sdb] Optimal transfer size 33553920 bytes
[62140.011721]  sdb: sdb1
[62140.011830] sd 3:0:0:0: [sdb] Attached SCSI disk
[62170.729827] sd 3:0:0:0: [sdb] tag#22 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[62170.729833] sd 3:0:0:0: [sdb] tag#22 CDB: Read(10) 28 00 1d 1c 58 80 00 00 08 00
[62170.736660] scsi host3: uas_eh_device_reset_handler start
[62170.850885] usb 2-3: reset SuperSpeed USB device number 9 using xhci_hcd
[62170.864525] scsi host3: uas_eh_device_reset_handler success
[62323.738996] sd 3:0:0:0: [sdb] tag#18 timing out command, waited 180s
[62323.739002] sd 3:0:0:0: [sdb] tag#18 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=183s
[62323.739005] sd 3:0:0:0: [sdb] tag#18 Sense Key : Not Ready [current]
[62323.739007] sd 3:0:0:0: [sdb] tag#18 Add. Sense: Logical unit is in process of becoming ready
[62323.739009] sd 3:0:0:0: [sdb] tag#18 CDB: Read(10) 28 00 1d 1c 58 80 00 00 08 00
[62323.739011] I/O error, dev sdb, sector 488396928 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[62504.431764] sd 3:0:0:0: [sdb] tag#19 timing out command, waited 180s
[62504.431771] sd 3:0:0:0: [sdb] tag#19 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=180s
[62504.431774] sd 3:0:0:0: [sdb] tag#19 Sense Key : Not Ready [current]
[62504.431777] sd 3:0:0:0: [sdb] tag#19 Add. Sense: Logical unit is in process of becoming ready
[62504.431785] sd 3:0:0:0: [sdb] tag#19 CDB: Read(10) 28 00 1d 1c 57 80 00 00 08 00
[62504.431787] I/O error, dev sdb, sector 488396672 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[62785.469294] usb 2-3: USB disconnect, device number 9
[62785.479256] sd 3:0:0:0: [sdb] Synchronizing SCSI cache
[62785.595197] sd 3:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Is there any hope to recover data from this drive?
 Post subject: Re: Samsung 850 Evo - suddenly gave up, any chances left?
PostPosted: September 12th, 2023, 14:20
Did you mangle that serial number?
Can you retrieve a SMART report with smartctl?
PostPosted: September 13th, 2023, 1:28
No, that's what is reported.
No, it kind of hangs:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.4.11-1-liquorix-amd64] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Read Device Identity failed: scsi error device will be ready soon
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
And then this also shows up in dmesg:
[90482.487883] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
[90496.356846] program smartctl is using a deprecated SCSI ioctl, please convert it to SG_IO
Users browsing this forum: No registered users and 123 guests
