 Post subject: PINOUT for SanDisk extreme micro SD Card 64GB
PostPosted: September 26th, 2023, 9:09
on spider board and mr21 adapter the card become no ID.
Have anyone an idea about the PINOUT for this card?
 Post subject: Re: PINOUT for SanDisk extreme micro SD Card 64GB
PostPosted: September 26th, 2023, 10:51
Should be standard 7x3 in my opinion. If it's not shorted and gives no ID when soldered or in adapter than it should be checked with logical analyzer.
BTW. MR-21 has alternative pinout too. Did you read the manual how to use this adapter?
odzyskiwanie danych
PostPosted: September 26th, 2023, 14:22
This is standard pinout but this Micro SD card use ECC LDPC + probably is encrypted, data cannot be recovered from it.
PostPosted: September 26th, 2023, 16:45
Chip-off impossible due to LDPC. But card have some corrosion or damage connector pads. Try fix it, ant maybe you get the data.
Users browsing this forum: No registered users and 14 guests
