 Post subject: help with locked rom
PostPosted: October 10th, 2023, 21:46
Hello, I have a WD40NDZW disk with pcb 810035 that has a slow response with bad sectors but I cannot correct it because the rom is blocked, with pc3000 or MRT I know that this can be solved, but I do not have those tools, it can be done with some software Or can someone help me. https://www.mediafire.com/file/k7q0kukh ... 5.BIN/file Thank you
 Post subject: Re: help with locked rom
PostPosted: October 11th, 2023, 3:08
Unlocked with MRT, try it and let us know. :wink:
https://www.mediafire.com/file/ygpi61ex ... 5.BIN/file
My firmware database:
PostPosted: October 11th, 2023, 13:21
Try also this 2nd version of unlocked rom if 1st doesn't work.. it has few different bytes compared to 1st unlocker rom.
https://www.mediafire.com/file/ziuwj2jy ... 5.BIN/file
most likely the 2nd unlocked rom is better.
PostPosted: October 11th, 2023, 21:44
Thank you very much, it worked perfectly, problem solved, thank you for your time
PostPosted: October 12th, 2023, 4:19
The 1st or the 2nd?
What tool did you use to fix slow reading on WD drive?
PostPosted: October 12th, 2023, 19:11
Aaannnd he is gone :lol:
PostPosted: October 13th, 2023, 0:38
The first rom worked perfectly and with wd marvel I eliminated the slow response
PostPosted: October 13th, 2023, 5:42
Nice :wink:
Users browsing this forum: Google [Bot] and 48 guests
