 Post subject: RE:Flash card recovery
PostPosted: June 21st, 2005, 3:10
Hello All,
Who's can share a information about Flash card recovery
tools and program? I'm looking it for full solutions of
Flash recovery. :roll: :?
Thank you.
David
 Post subject:
PostPosted: June 21st, 2005, 5:52
With Stellar Phoenix you can recovery flash card.
 Post subject:
PostPosted: June 21st, 2005, 6:26
From my memory most software data rec will work... I think CF will mount as floppy drive FAT 12... maybe Im wrong cannot remember :oops:
 Post subject: RE:Thanks you
PostPosted: June 21st, 2005, 6:36
Hi my friends,
Thanks for your information.
This is for detected device only. If the Flash device not detected,
what tools should be use?
Thank you.
David
 Post subject:
PostPosted: June 22nd, 2005, 1:18
I use an external eeprom reader for physical cases and Photorecovery for Digital Media for the software ones (ie: flash does not mount - no files at drive letter).
Also a good USB card reader all in 1 (mine is 21 in 1) is of great help ;)
-BR-
 Post subject:
PostPosted: June 22nd, 2005, 11:47
-BR-
HI BR,
Thank you for your help too.
Which brand of eeprom reader is the best? Is it must be solder out
the eeprom IC before using a reader?
Thank you.
David
 Post subject: Re: RE:Flash card recovery
PostPosted: June 22nd, 2005, 12:58
David Sam wrote:
Hello All,
Thank you.
David
I suggest using WinHex. I've achieved the best results with this software.
 Post subject:
PostPosted: June 23rd, 2005, 0:36
Yes David, you must first unsolder the eeprom (generally TSOP-40) from the pcb before reading ...
I do not know which is best, but Xeltek 3000U have never failed me ;)
PostPosted: June 23rd, 2005, 20:38
Thanks you for BR.
This Xeltek 3000U is easy to use?
Is stand alone or connected with computer?
David
 Post subject:
PostPosted: June 23rd, 2005, 23:01
USB connected. The programmer itself is very easy to use. The most difficult part is to have the correct skills to unsolder the tsop component.
 Post subject:
PostPosted: June 24th, 2005, 2:25
to David Sam:
It's easier to get an working flash card an replace the TSOP flash memory with the one from the bad card (must be identicall), but, how -BR- said, you must have good soldering skill.
DE AD
 Post subject: RE:OK
PostPosted: June 24th, 2005, 4:54
b_wonderer_a wrote:
to David Sam:
OK! for technical side, I will practise as much as I can.
Let said If I got one MMC flash card is undetected, I need is
just unsolder out TSOP and put in Xeltek to read it or can I
sold/swap TSOP to a good MMC flash card? And how can I know
which TSOP pin is for power and which pin is for DATA,time, etc?
Is it all Flash TSOP is the same architecture?
Thank you.
David
 Post subject:
PostPosted: June 24th, 2005, 9:59
'perhaps' there is a type number on the IC that u may feed to Google :)
 Post subject:
PostPosted: June 24th, 2005, 23:25
David:
If you use Xeltek, there is a great software bundled that identify the tsop by its code and give you full needed pinout.
Also, i prefer to read its data in external eeprom header because of some reasons:
1 - It does not damage an extra card (probably new, because you can not have it all)
2 - Something can go wrong in the re-soldering process, and you can loose data forever (like if you broke a data pin)
-BR-
PostPosted: June 26th, 2005, 21:06
-BR- wrote:
David:
-BR-
Hello BR,
Thanks for your info again.
Is it everybody also using a Xeltek to recovery Flash data?
I need is buy all Xeltek tools then can be start to do Flash recovery data business? or still need others equipment?
Thank you.
David
Users browsing this forum: No registered users and 129 guests
