Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: software test badblock hdd
PostPosted: November 1st, 2023, 4:43
There are several types of tests and configurations within Victoria, I need guidance on which one to choose
PostPosted: November 1st, 2023, 7:11
This will be my last answer to you about this subject: https://www.youtube.com/watch?v=8hDMnyMdJsM
ACELab partner
PostPosted: November 1st, 2023, 8:12
TBH the video gives me Dunning-Kruger vibes ..
PostPosted: November 1st, 2023, 10:34
Just to show the buttons and features... :mrgreen:
ACELab partner
PostPosted: November 1st, 2023, 11:27
I'll keep it in mind, maybe it's a nice topic to make video about in my own clumsy way ..
PostPosted: November 1st, 2023, 17:46
I'm sure you will have viewers! At least I know one (no, not me)
ACELab partner
:lol: :lol:
PostPosted: November 1st, 2023, 18:19
We all know a guy that is a "computer guru" meaning he has carried around a USB full of the same portable apps since 2014, and always has a Hirens handy. He is the one on the computer at any party, running defrag and clearing the windows/temp directory
PostPosted: November 1st, 2023, 20:49
:lol:
PostPosted: November 2nd, 2023, 3:55
I was that guy!!!!! Any problems?!?!?! ahhahaha
ACELab partner
PostPosted: November 2nd, 2023, 16:14
:lol:
PostPosted: November 5th, 2023, 15:00
I tested my HDDs Victoria Are these HDDs only good for storing files? two hdds 1TB
PostPosted: November 5th, 2023, 20:22
if you want a screenshot of your active window, hold ALT and hit print screen. it just does the window, not the whole screen.
here is the manual that you can translate and work out what you are looking at in the results yourself. https://hdd.by/victoria_doc1/
PostPosted: November 5th, 2023, 20:24
I don't have the technical knowledge to analyze this test
I took the test that you guided me by sending a video
PostPosted: November 6th, 2023, 15:56
Did you analyze the photos? Are both two HDDs good for storing files or no?
Another question, one of the HDDs the test graph does not go up to 1TB it stops before 1TB and the test is two minutes shorter, is this normal?
PostPosted: November 6th, 2023, 16:59
if you want to make sure hdd is realiable, do a full scan. Quick scan gives a fast idea how the health is.
Smart for both hdd seems to be ok (if nobody made a smart reset).
Second hdd should be tested til the end.
PostPosted: November 6th, 2023, 17:52
Is a new test on HDD2 really necessary or are the tests that have already finished on both HDDs enough for both HDDs to be good for storing data? I posted photos of all the tests, Smart etc. What opinions this tests completed?
PostPosted: November 6th, 2023, 19:26
yes, do 2 full scans. If these are OK, then put drives inside a safe with 2m thick concrete walls. Build a new computer using all certified, guaranteed hardware that will not fail. Call the power company and get a dedicated, filtered, power supply that has multiple fail-safes built in. Clear your Neighborhood of people so there is no chance of anyone interrupting the data transfer. Stop all Wi-Fi, cellphone data in the area to make sure there is no interference. make sure there are no magnets in the immediate area, 1KM to be safe. Remove ALL CATS from the surrounding area - Cats are very bad for computers, laptops especially. make sure there are no glasses of wine close. These are also a natural enemy of computers.
Once you are certain the data transfer will work, test 3 times by cloning your data then restoring it. do a binary file comparison to make sure data is the same.
If this is ok, throw away your whole system and build an identical one - you can't trust it now you have used it 3 times.
backup your data, encase in concrete and bury in your backyard. Make a sign 'NO HARD DISKS BURIED HERE' to trick any criminals digging it up and stealing your drives.
follow these simple steps and you can be slightly ahead of if you just use your perfectly fine drives.
It would be ironic if for some reason your PC crashed and you lost all your data, after spending 2 years drilling down every little possible 'what-if' and never actually just did the backup.
PostPosted: November 6th, 2023, 19:52
Were the Smart + quick scan Victoria tests that I did is not useful for my HDDs to know their health?
PostPosted: November 6th, 2023, 19:54
you are not going to be satisfied with ANY test, so it doesn't matter what you are told
