 Post subject: Sandisk X300 diagnostics
PostPosted: November 2nd, 2023, 2:21
Hi friends
I want to know how to diagnose SANDISK X300 M.2 SATA SSD. It has no detection and I think it has electronic issue.
I have basic electronic knowledge so can check voltages but lack anything about smd and signal tracing etc.
any help will be appreciated.
 Post subject: Re: Sandisk X300 diagnostics
PostPosted: November 2nd, 2023, 3:54
Can you see if anything is heating up?
ACELab partner
PostPosted: November 2nd, 2023, 7:07
Is this a clients drive or your own drive you are planning to experiment on ?
I would start to compare measurement from a working identical drive. Maybe check if it IDs in safe mode.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: November 2nd, 2023, 8:56
hi pclab
Yes I have checked it momentarily , its not getting heated up. Physical inspection also doesn't show any burn marks.I think something is shorted.
Thanks.
PostPosted: November 2nd, 2023, 9:00
Hi digisupport
Its my clients ssd. I don't have identical one. I have asked client to provide the same as they have similar drives. I have a pc3k-udma only so can't take it in safe mode. I am trying to get schematics also.
PostPosted: November 5th, 2023, 13:20
Perhaps you should outsource these jobs to an electronics technician? I would think there would be plenty such people in India.
If you do find a circuit diagram, please let us know. I would try to help you, but your photo is blacker than Donald Trump's heart.
PostPosted: November 5th, 2023, 23:58
hi fzabkar
Thanks for your help. Yes photo is not clear ,I will try to give photo. I think since sandisk mcu is not supported we can solve this case if issue is restricted to electronics level only.
I can at least check basic voltages to conclude if we get schematics. I will update once I get it.
