Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: HDD Burned on gas stove, can it be recovered?
PostPosted: November 14th, 2023, 23:00
FatRaccouunn wrote:
My brother burned my HDD on the gas stove for about 5 minutes with the cover open, can data be recovered from it?
I've seen and recovered drives that look something like this but of course, it's almost impossible to say without testing and seeing the actual drive. It's a time-consuming process but not hopeless. You need to send it to some reputable DR company, there are not many who can or will do this kind of work. :wink:
Usually, if the plastic has melted inside there's no chance to recover but this is not always the case, I recently recovered one house fire case and the head ramp was melted quite badly but I was still able to get +90% of the data back.
PostPosted: November 16th, 2023, 5:03
Most important thing is if Curie point has been reached and magnetic properties have been lost. If so, it's not a hard drive anymore, data is gone and you should move on.
PostPosted: November 16th, 2023, 5:46
as i said, the question is most likely not curie temp here, but the possible lubricant layer disintegration. In any case, it is not possible to tell it for sure without trying, but there mu$t be $ufficient need with $ufficient 'will' to $upport the action...
PostPosted: November 16th, 2023, 18:14
there is no lubricant on WD drives, they use diamond layer.
PostPosted: November 16th, 2023, 18:33
then that :) whatever covers the surface...
Users browsing this forum: Google [Bot] and 65 guests
