 Post subject: Background scanning - -SYS 93 & SMP -
PostPosted: November 22nd, 2023, 0:37
Disk -- ST1000LM035 /SDM2
I am unable to stop background scanning in SYS_03_93_00 when I try to write file I get error
While I have been able to edit hdd ID & I have modified it.
I have tried Terminal ,Direct & Indirect writting but each give different errors .I can't read sys files as well. I get LED error
head resistance is as following -
Head 00 Resistance 0239
Head 01 Resistance 01A7
I want to know whether this is head related issue or SA issue.
 Post subject: Re: Background scanning - -SYS 93 & SMP -
PostPosted: November 22nd, 2023, 5:21
system files corruption and weak head 0
PostPosted: November 23rd, 2023, 6:17
Thanks I have fixed corrupt file and have stopped background scanning.
But still getting read errors due to TEC sectors. How to deal with them.Also I want to confirm SMP modifications are correct are not.
PostPosted: November 23rd, 2023, 8:24
Put lower timeouts so that they will just report bad. Play with AFH or change heads to get those sectors read.
PostPosted: November 25th, 2023, 0:42
Thanks changing heads and lower timeout worked magically 100 % Data recovered despite TEC. :-D
