 Post subject: After turning on the pc, it appears : SSD Locked and ...
PostPosted: December 31st, 2023, 10:23
Good morning everyone.I have an Acer Veriton desktop pc, Windows 11 Pro.One day I turn on the pc and suddenly it appears :
"SSD Locked" and then "Enter User Password".Windows won't start.I never entered password,neither on bios nor windows !!Victoria software says : "SSD locked by ATA PASSWORD".I would like to at least be able to see what files and folders are on the ssd.If I can then also save the data, even better.
My ssd is : MyMedia 2.5" Sata III 7mm 256 GB.I reset the Bios by both removing the CR2032 battery and moving the Cmos jumper : all to no avail.
Could someone please help me ? Thank you !!
 Post subject: Re: After turning on the pc, it appears : SSD Locked and ...
PostPosted: January 1st, 2024, 8:51
I add 2 more photos
PostPosted: January 2nd, 2024, 18:32
did you call Acer?
PostPosted: January 3rd, 2024, 3:04
yes.I would have to ship my desktop pc to their labs and I think the cost to fix this problem is high...So I'm not going to do anything with Acer
PostPosted: January 4th, 2024, 10:38
try the following password:
25547215
PostPosted: January 4th, 2024, 11:05
I will, thank you.Then I will let you know !
PostPosted: January 4th, 2024, 14:14
Appears: invalid password
PostPosted: January 4th, 2024, 14:28
If you install the SSD in another machine, or attach it via USB, are you then able to retrieve a SMART report? I'm wondering if the SSD really is locked, or if that is a symptom of a firmware "panic".
PostPosted: January 4th, 2024, 21:45
sorry, I didn't read that it was HDD password and found this site hoping it would help https://www.biosbug.com/acer/
PostPosted: January 6th, 2024, 9:11
Good morning, I tried to enter 4 codes generated by the site :https://www.biosbug.com/acer/ : it always appeared me "Invalid Password"
PostPosted: January 6th, 2024, 9:29
I put the ssd in a case and attached it via usb to a running pc.I attach 2 screenshots of the Victoria software
PostPosted: January 6th, 2024, 9:30
here is the other screenshot
PostPosted: January 7th, 2024, 19:45
I believe that site is for BIOS access password, not HDD Lock Password. You would have to get into BIOS first to remove HDD password, but you also would need to know the password to remove it I would think
Users browsing this forum: No registered users and 139 guests
