 Post subject: Operation terminated at offset 0 LBA 0
PostPosted: January 9th, 2024, 9:11
I cloned 10different SSDs with Host OS to keep as backup, so in case some of them will die, I will quickly deploy same OS on new SSD from image backup...Now I tried to clone the saved image on new and larger SSD, but I get "Operation terminated at offset 0 LBA 0" error...
I tried 5 different new disks, still the same.
I tried to connect the disk both 1. directly on SATA cable, and 2. with USB-to-SATA converter as external disk, still the same.....
Any ideas?
 Post subject: Re: Operation terminated at offset 0 LBA 0
PostPosted: January 10th, 2024, 11:51
This is what I get :
10. 1. 2024 16:50:01 Copying...
10. 1. 2024 16:50:01 Write Error occurred at offset 0 (19)
10. 1. 2024 16:50:01 Cannot write to target, aborting...
10. 1. 2024 16:50:01 Average speed:
10. 1. 2024 16:50:01 Operation terminated at offset 0 LBA 0
PostPosted: January 10th, 2024, 11:55
Dude, we don't have the foggiest idea what you're doing and what you're using to do it.
Sounds like a problem with the destination drive.
PostPosted: January 10th, 2024, 13:12
We have no idea what is you setup, what software you are using and so on.
If you are using Windows make sure that your new SSD doesn’t have MBR with valid partition table. If it does Windows can block write attempts to that drive.
