 Post subject: WD5000BMVV-11SXZS1 head selection.
PostPosted: January 31st, 2024, 7:06
I need heads for this drive. Will any set of heads with the same model and month/country of manufacture work or are there any characters that must match in the DCM code or elsewhere.
 Post subject: Re: WD5000BMVV-11SXZS1 head selection.
PostPosted: February 21st, 2024, 15:08
same model with DCM TJ or VJ same as patient would be okay.
Good Luck...
PostPosted: February 27th, 2024, 11:28
Gordon Bulger, Hi, my experience is to look for a model with *SXZS* (in this case). When the DCM fits (TJ, VJ or T2) would be even better. Sometimes the sizes are diffent, but should not be a problem (important is the numbre of heads). I had a lot of different successful cases, where the sizes where different. Hope this helps you.
Users browsing this forum: No registered users and 78 guests
