 Post subject: WD Blue PCB change
PostPosted: February 9th, 2024, 11:31
Hey you all!
I was wondering if anyone here has changed PCB on WD Blue WD10EZEX?
I tried doing it but ended up finding "uknown device" from device manager..
My exact model of HDD is WD10EZEX-21M2NAO
Donor of the PCB is WD10EZEX-60M2NAO
Does that tiny bit on model make that much difference that it does not work at all?
Worth to note is that my original HDD got fried by faulty PSU, so in that case, shouldn't PCB swap help?
Thank you for reply! :)
 Post subject: Re: WD Blue PCB change
PostPosted: February 9th, 2024, 12:33
You need to transfer the ROM (aka "BIOS IC") from patient to donor.
https://www.hdd-parts.com/17124544.html
https://s.turbifycdn.com/aah/yhst-14437584971410/91710965-14.gif
"Adaptives" -- why a straight PCB swap doesn't work in modern hard drives:
http://www.hddoracle.com/viewtopic.php?p=19090#p19090
Users browsing this forum: michael chiklis and 59 guests
