 Post subject: WDC External USB - MCU Encryption
PostPosted: February 8th, 2024, 6:37
Hello. Good morning companions.
Not long ago I received a unit with data encryption by MCU with USB PCB 810035. Therefore, the MCU and ROM must be transferred to the donor unit SATA PCB 810030.
I wonder if there is a list of USB PCB drives that have this encryption?
I have this list:
800041
800067
800069
810003
810012
810033
810067
810035 MCU Encryption
I can only confirm the 810035. Can anyone confirm the other models?
 Post subject: Re: WDC External USB - MCU Encryption
PostPosted: February 8th, 2024, 6:52
It actually depends on the drive firmware and release date.
After a certain point, WD started releasing families encrypting with MCUs where previously a compatible SATA or unlock board would get you access to SA and sectors.
AFAIK I think it's later Spyglass families (Spyglass 2, Spyglass Ultra Light, Spyglass 3 )
Newer Chargers, Newer Palmers
I don't know if someone has listed the models, but I'd say if the date of manufacture is after 2020, then there is a good chance it is.
PostPosted: February 10th, 2024, 16:26
You have to ask the USB PCB models. I want to know which of those models have MCU Encryption.
Users browsing this forum: Google [Bot] and 65 guests
