Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: Wd40edaz-11u78b0 Not Spinning
PostPosted: February 15th, 2024, 15:37
Done it but it didn't spin
PostPosted: February 15th, 2024, 15:43
And not even detecting on Windows device manager but previously it was detecting
PostPosted: February 15th, 2024, 15:56
This makes no sense. If the drive was not getting 5V and 12V, then the MCU would not have been alive, in which case the drive would not have been able to communicate.
Can you now measure the voltages at all those test points?
PostPosted: February 15th, 2024, 16:21
M041633n wrote:
Yes Customer told it was fallen
Most likely heads are gone.
That's why the drive won't spin up.
PostPosted: February 15th, 2024, 16:26
How does this account for the e-fuse being open on both sides? I don't think we're getting the real story.
PostPosted: February 15th, 2024, 16:51
Powered or not powered ??
PostPosted: February 15th, 2024, 16:56
If this is a clients drive, don't you think it's time you sub contracted this one out to someone with a little more experience.
PostPosted: February 15th, 2024, 16:59
Try it both ways and then try to understand why you get the results that you do.
PostPosted: June 25th, 2024, 7:29
What if I replace the PCB with the Donor PCB will it work without any modifications??
PostPosted: June 28th, 2024, 20:49
I would try with a donor PCB first. to skip the headache of diagnosing PCB
PostPosted: June 29th, 2024, 9:16
If I have the donor pcb what should I've to do next Mr.LostDataSa
Users browsing this forum: No registered users and 51 guests
