 Post subject: ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE
PostPosted: February 14th, 2024, 21:57
Hello guys hows your new year?
i received this drive that doesnt spin at all and stay BSY with error LED:0x000000BD FAddr:0x000059D8
iv tried the official guide https://blog.acelab.eu.com/how-to-fix-a ... -chip.html
but with donor PCB "after Repeat the unlocking steps (1-6) " i cannot enter the command OI1 ..... i will get LED:0x000000BD FAddr:0x000059D8 !AGAIN
and if i skip this command and Repeat the unlocking steps (7-9). the drive spinds but i get Waiting drive spin up ! therefore i cannot use the terminal !
with original PCB is the same.....the drive spins if i change to 82 34 56 78 but i cant enter the command OI1
i also noticed that nomatter how many times i write the patient rom into DONOR PCB it will show the SN of the DONOR.........
any help will be very very helpfull
 Post subject: Re: ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE
PostPosted: February 16th, 2024, 3:45
try ROm Programmer to write Patient ROM or change Terminal Speed,
Good Luck...
PostPosted: February 17th, 2024, 9:10
Good Luck...
programmer ? Sir this drive has no tsop rom on it! the rom is stored inside the nand flash!
anyway when i disconnect the pcb from the patient drive it gives me the patient SN but when i connect to the patiend hdd it shows the donor drive SN
PostPosted: February 17th, 2024, 11:10
it has NOR flash (serial flash) albeit not TSOP indeed, but BGA. It is the ~3x2mm chip near the DRAM.
ROM is also present in NAND and some parts of it are read from there normally.
PostPosted: February 17th, 2024, 11:58
yes right Sir . you 100%...unfortunatelly im stuck.................... maybe non compatible BGA on the donor? but the drive spins when i set 82 34 56 78
however BSY and same terminal error
PostPosted: February 20th, 2024, 1:41
can somebody tell me which is the correct position for the read channell? i tried many times but is still get the error LED:0x000000BD FAddr:0x00008004
should i short before or after the tech Unlock Handshake"?
should i keep the position untill the drive get ready ? if the position is correct will the drive keep spinning or will stop spins?
Users browsing this forum: No registered users and 104 guests
