 Post subject: WD 4TB My Passport PCB doesn't have power? 2060-800041-003
PostPosted: March 5th, 2024, 6:30
I got a 4TB My Passport Drive from WD. That doesn't show any sign of life on the PCB. The USB connector is fine. I soldered a Sata connection to test the PCB. There is 0 amps drawn on 5v rail
I wanted to know if someone could provide me with crucial measuring points, components and voltage rails of this PCB
Many Thanks!
429831711_1223026852416055_882733543940679899_n.jpg [ 173.41 KiB | Viewed 8870 times ]
431227343_774970944530294_6974401377687789215_n.jpg [ 151.11 KiB | Viewed 8870 times ]
 Post subject: Re: WD 4TB My Passport PCB doesn't have power? 2060-800041-0
PostPosted: March 5th, 2024, 6:38
measure the 000 ohm resistor in between the 2 connectors with a multimeter, diode/continuity check mode. it should beep.
PostPosted: March 5th, 2024, 6:57
It probably will beep. The usual fault is dry solder joints at each end of the resistor, not the resistor itself. Reflowing the solder should fix the problem.
PostPosted: March 6th, 2024, 5:26
Small question guys. In case the PCB is badly damaged. What chips you need to swap to the donor in order for the PCB to work? I heard that with these new SMR drives not only BIOS need to be swapped?!
PostPosted: March 6th, 2024, 10:34
Some of these PCBs have a key in the MCU, so that means you need to transfer the MCU as well as the ROM.
To answer your original question, here are the test points:
https://web.archive.org/web/20210614193827/http://www.users.on.net/~fzabkar/HDD/WD40NDZW_TVS_diode_fuse.jpg
https://web.archive.org/web/20230730202427/http://www.users.on.net/~fzabkar/HDD/WD40NDZW_bridge_Vcore.jpg
https://web.archive.org/web/20220113231223/http://www.users.on.net/~fzabkar/HDD/WD40NDZW_regs.jpg
PostPosted: March 8th, 2024, 3:50
Okay. So i measured all the points in 3 pictures as well as the 0 Ohm resistor. all of them seems fine
I measured across 1 donner working board.
There are 3 things
1st, i tested heat spot from the donor board vs the broken board. It seems missing the heat from the SATA controller. Means the voltage is not getting there
2nd, upon turning the broken PCB board on the LED light lights up but very DIM. Not bright as the working one. The PC3000 showing jumping amps between 16-20 on 5v and the PCB stayed BSY
3rd, i did found a W1P 87 transistor that shows different measurements i guess it might be the culprit or maybe the SATA controller itself. I will try swapping them over. Hope for the best
If anyone have any ideas please let me know
Many thanks!!!
File comment: Dim LED light and Transistor that showing different measurements
427154482_1056682495419450_1770902453019812534_n.jpg [ 303.79 KiB | Viewed 8635 times ]
File comment: Voltage and Amperage on broken PCB
429764983_699012102442160_6400887165765662139_n.jpg [ 118.15 KiB | Viewed 8635 times ]
File comment: Non working PCB heat spots
431076752_390038943875079_3364916298629566556_n.jpg [ 137.49 KiB | Viewed 8635 times ]
File comment: Working PCB Heat Spots
430433189_1521515428415491_275423114085729135_n.jpg [ 129.13 KiB | Viewed 8635 times ]
PostPosted: March 8th, 2024, 5:17
New findings. So apparently the LED is fried that's why the Transistor has different measurements. Swapped the LED now shines bright
I found a broken trace at the MCU that maybe the cause of this. Trying to solder those points but haven't got luck cause the points are small
427154482_1056682495419450_1770902453019812534_n.jpg [ 150.04 KiB | Viewed 8621 times ]
431145048_382015634563121_6467742487815195774_n.jpg [ 164.69 KiB | Viewed 8621 times ]
PostPosted: March 8th, 2024, 5:39
A broken solder joint wont be the source of a short - nice catch though.
If you're struggling with soldering and can't justify the JVC kit (who can) an Axium T115 station is cheap enough and will have no problems at that scale with decent optics.
PostPosted: March 9th, 2024, 6:45
- So I measured all components but found no short on the board. Does it mean that the only thing can go bad is the SATA Controller chip???
- I will find a way to solder that. Just not at the time when i was writing the comment :P just a little bit of struggling :P
PostPosted: March 9th, 2024, 7:28
A little off on the scale there. 150-200mA could be standard drawn on the board, check with a donor. Assuming you've reflowed that troublesome resistor that sort of pattern is usually an IC failing to start and whilst your thermal camera show "hot spot" these aren't hot enough not to be normal operation. Given all the major IC's appear to be getting power I'd start looking at enable signals but check your voltage rails anyway. Also look at the pcb on edge - is it flat ?
PostPosted: March 9th, 2024, 14:22
Just FYI, a transistor is often used to drive a device whose current requirements are greater than that which can supplied by the MCU or bridge.
    MCU I/O pin --> transistor --> LED
http://markingcodes.com/search/c/W1P
PMBT2222A, NXP, NPN switching transistor, 40V, 600mA, marking *1P, SOT23:
https://datasheet.lcsc.com/lcsc/1811141239_Nexperia-PMBT2222A-215_C23869.pdf
Have you dumped the MCU ROM? Perhaps it is corrupt? I have written a tool to check its consistency.
BTW, did you measure the voltage on that MCU pin to confirm that the trace is indeed open?
PostPosted: March 11th, 2024, 5:16
I have not. How can i get hold of your tool to check its consistency???
Apparently there are also problems with the ROM chip above
I thought this ROM is locked and need unlocking procedure with PC3000 but apparently After pogoing, reading the rom out after verifying with pogo sticks many times. The ROM has a lot of errors. I'm supper blind now. Don't know where to go from here, or what causing all of this
I am sending the ROM hopefully some one could check it out for me
PostPosted: March 11th, 2024, 5:17
https://drive.google.com/file/d/1T0h6mM ... drive_link
PostPosted: March 11th, 2024, 10:37
https://web.archive.org/web/20230730051707/http://www.users.on.net/~fzabkar/FreeBasic_W32/WD/wdROMv17.bas
https://web.archive.org/web/20230730051707/http://www.users.on.net/~fzabkar/FreeBasic_W32/WD/wdROMv17.exe
PostPosted: March 12th, 2024, 2:42
Can you take a look for me. Or tell me how to use that .exe program???
PostPosted: March 12th, 2024, 12:56
The tool runs from the command line in a Windows DOS box. Just type the name of the file to see the embedded usage instructions.
As for your ROM dump, it has hundreds of errors.
PostPosted: May 8th, 2024, 21:25
Yeah. I found out that the ROM is broken. Are there anyway that i can fix this?? I believe that each drive has unique ROM isn't it?? So this case is unsolvable??
PostPosted: May 8th, 2024, 21:48
Take several ROM dumps and upload them. If you have a good donor ROM, either USB or SATA, could you upload that as well?
Users browsing this forum: No registered users and 69 guests
