 Post subject: FirstChip FC2279 BA7
PostPosted: March 22nd, 2024, 8:30
Anyone ?
128GB Integral flash drives both NAND BGA-132
Controller : FC2279 BA7
First Drive
NAND : ACELW2201N38A-H
Second Drive
NAND : JKQXN38B2243-1002A
Neither chip will ID on PC3000 Flash VCC 2-3.6v Drops out with reset errors at 1.8v. Drive #2 is known good and working.
 Post subject: Re: FirstChip FC2279 BA7
PostPosted: March 22nd, 2024, 9:54
Ask question.
Show Chipgenius info from second drive.
PostPosted: March 22nd, 2024, 10:21
From Drive #2
Without NAND - would need to reball if you need it with. Looks to be the same as result from drive #1.
Description: [E:]USB Mass Storage Device(NAND USB2DISK)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 100mA
USB Device ID: VID = FFFF PID = 1201
Device Revision: 0000
Manufacturer: NAND
Product Model: USB2DISK
Product Revision: 0.00
Controller Vendor: FirstChip
Controller Part-Number: FC1178BC
Tools on web: http://dl.mydigit.net/search/?type=all&q=FC1178BC
PostPosted: March 22nd, 2024, 11:22
Ah, I thought that you not desolder chip from Drive #2. Anyway, I have feeling that memory chip could be 6th byte addressing.
PostPosted: March 22nd, 2024, 11:23
Nand attached : These pcbs are so cheap and flimsy I'm having to replace the mask each time otherwise the chip skids all over the place.
Description: [E:]USB Mass Storage Device(VendorCo ProductCode)
Max Current: 100mA
USB Device ID: VID = 346D PID = 5678
Serial Number: 6610641276322786643
Device Vendor: USB
Device Name: Disk 2.0
Device Revision: 0200
Manufacturer: VendorCo
Product Model: ProductCode
Product Revision: 2.00
Flash ID code: 89D3AC32C204 - Intel - 1CE/Single Channel [QLC] -> Total Capacity = 1GB
Possible Flash Part-Number
Unknown
Flash ID mapping table
[Channel 0] [Channel 1]
89D3AC32C204 --------
1A2B3C4DE5D4 --------
CB75EFCD188B --------
CB741A803C00 --------
BB007CB80102 --------
4F75EDBEA306 --------
55AA75C78BF5 --------
1GB - Fake ?
Edit : Not fake according to grc's validrive.
PostPosted: March 22nd, 2024, 12:08
I have at past case with ID: ID: 89 d3 ac 32 c6 00 (it was solved) - it was 6th byte addressing chip. So here should be same. Chip have 128GB - but according to FC controller there is chance that it will be refurbished and not use all capacity.
PostPosted: March 23rd, 2024, 5:59
Looks like you're right about the chip, after much persuasion I managed to get this from it. I'll return this as above my pay grade and pass on your details again. I leave this here so the next person doesn't waste time with Ace TS.
This is from drive #1 flash marking : ACELW2201N38A-H
Flash ID code: 89D3AC32C600 - Intel - 1CE/Single Channel [QLC] -> Total Capacity = 1GB
Unknown
89D3AC32C600 --------
PostPosted: March 23rd, 2024, 11:26
Case should be recoverable. Not so easy, but possible. I think all TS give up such cases at this moment ;)
PostPosted: March 27th, 2024, 7:36
See this VNR Update -> https://rusolut.com/visual-nand-reconstructor-8-0/
PostPosted: March 27th, 2024, 12:07
Reading this NAND flash currently is not a problem, but it requires modified hardware and software. PC3K explained the data recovery method for FC1179 controllers on its support blog two years ago, but the cases presented were ideal scenarios. The reality is that if you follow the guidance on the blog, the success rate will drop as low as 5%. Currently, nobody has the capability to perfectly solve the majority of FC controllers. Some individuals may perform better to some extent, but that's about it. The challenges stem from poor flash quality, adaptive bad bits, varied ECC algorithms, adaptive XOR, intra-block page clipping, sector clipping, unusual block mixing modes, partial block loss leading to incomplete file systems... I don't believe I'm doing well in this aspect. Over the years, I've encountered many people claiming to excel in recovering FC controller cases, but after some exchanges, most of them are exaggerating, and in many aspects, they are even worse than me.
http://flash-matrix.com/
PostPosted: March 27th, 2024, 12:59
Which for me at least, means it's a problem. If the chip can't be read with commercial tools without mods to those tools it's not economically viable to recover. I saw Aces blog post - it starts having already read the chip. As I see it, it's a complex case all round, problem nand, problem controller - best left to the flash specialists I have enough problems :lol: .
