 Post subject: Brinks on the Brink - Pls salvage
PostPosted: May 10th, 2024, 1:35
Hard Disk is ST3320613AS / CC2H ~ Brinks Family.
While disk gets detection and I have been able to read some system files too. While imaging in DE disk starts clicking and becomes busy with detection loss.
I think it could be SA defects or weak failing heads. Customer has few photos to be recovered so its low cost FW job only .
I can't change settings in sys 93 (SMP) as drive starts clicking .It has something to do wit MC.
Any tip or trick I can try?
Here is Terminal & full log
LED:000000CE FAddr:0025FE1F
Rst 0x10M
(P) SATA Reset
PASSPackage Verified
Send Status: COMRESET seen
LED:000000CE FAddr:0025FE1FL E D : 0 0 0 0 0 0 C E F A
LED:000000CC FAddr:00260A69
Rst 0x10M
(P) SATA Reset
ASCII Diag mode
F3 7>X
Head 00 Resistance 0107
Head 01 Resistance 016E
Full log -
******************** 5/6/2024 10:22:47 PM ********************
HDD family detecting...
Family ID: 2D
Software can`t control COM port signal level for this USB/COM adapter
Selected family......................... : 2D, Brinks
Model by ID............................. : ST3320613AS
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Requesting FW Pkg ver ........
BR140D.CCD2.CG0H0H.CC2H
Detecting SA Phys Sct Size...
Result.................................. : 512
Detecting UA Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 2
Obtaining Saved Mode Pages File information...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
LBA alignment........................... : 0
Obtaining Registry File information...
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
Collecting Sys Files information...
ID Len
0 4 Reserved Defect Table (SA defect table)
1 2 Drive Information File (DIF)
2 16 Performance Parameter File (PPF)
3 3787 Primary Defect File (P-List)
4 12 Servo Adaptive Parameter File (SAP)
5 4 Manufacturing Information File (MIF)
6 66 Read Adaptive Parameters File (RAP)
7 1 Controller Adaptive Parameters File (CAP)
8 4800
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
C 64000 Serial Port Test Results File (Self Scan Log)
D 160
E 432 Data Integrity Check (DIC), HEAD 0
F 223 DIC Dummy File
13 8 Disc Registry File (settings, security, etc)
15 100 BGMS File (Directed Offline Scan)
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
1D 128 Physical Overlay File 0
1E 128 Physical Overlay File 1
1F 640 Physical Overlay File 2
22 80 Drive Self Test (DST), Head 0
23 80 Drive Self Test (DST), Head 1
2A 9 Saved Mode Pages (HDD settings)
2B 928 R/W Operating Parameters (translator, etc)
2C 432 Data Integrity Check (DIC), HEAD 1
33 4576
34 640 Packed CONGEN XML definition
35 26 SMART Data
3A 4
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
ID MemOffs Len
0 6020100 33792 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4001000 4096 Servo Adaptive Parameter File (SAP)
602BE00 4096
total 8192
5 6C000 81920 Servo Firmware Table
A 60A6CF8 1024 Seek Profile
13 60B1CE0 544 Dependent Zone Table for User Area
14 60B1F00 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60B1008 3288 Dependent Zone Group Tables for User Area
1C 60B0EC8 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020310 2320 Zone Format Parameters File
RAM:
ID MemOffs Len
2 60201F0 288 Zone Table
602BE00 4096
total 8192
6 267A44 40996 Servo Flaw Table
16 6020100 32 Drive Configuration Table
17 6021F20 1744 Temperature Control Configuration
1F 6184690 1224 RW working user preamp table
20 6184B58 72 RW working system preamp table
Collecting DT Infos completed
System Files I/O method detection...
ATA(indirect)
Reading autotuning buffer...............
OkBuff Root FAT searching in RAM.........
OkSearching module table in RAM... .......
OkSearching DT table(RAM, WR) in RAM......
OkSearching DT table(RAM, RD) in RAM......
OkSearching volume 0 file table in RAM....
OkSearching volume 1/2 file table in RAM...
OkSearching volume 3 file table in RAM....
OkSearching volume 4/5 file table in RAM...
OkRequest for volume 9/A file allocation table in RAM
ErrorSearching SMP RAM FID in RAM............
OkSearching Non Resident G-List FID in RAM
OkSearching CFW OVL FID in RAM............
OkSearch for DBA Base in RAM..............
OkSearch for RW Sys File DBA in RAM.......
OkSearch for MCMT RAM FD in RAM...........
Error
Test : HDD resources backup
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Brinks\ST3320613AS-CC2H-9SZ3HWZ0\Data\SABackup\
Saving ROM to profile folder
File : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Brinks\ST3320613AS-CC2H-9SZ3HWZ0\Data\SABackup\ROM\ROM_9SZ3HWZ0_4C2FE543.bin
Result.................................. : Ok
Reading modules to profile folder
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Brinks\ST3320613AS-CC2H-9SZ3HWZ0\Data\SABackup\ModDir\
Will be skipped : 000C, 000E, 000F, 0022, 0023, 002C
Module 0000, Reserved Defect Table (SA defect table).................. : Ok
Module 0001, Drive Information File (DIF)............................. : Ok
Module 0002, Performance Parameter File (PPF)......................... : Ok
Module 0003, Primary Defect File (P-List)............................. : Ok
Module 0004, Servo Adaptive Parameter File (SAP)...................... : Ok
Module 0005, Manufacturing Information File (MIF)..................... : Ok
Module 0006, Read Adaptive Parameters File (RAP)...................... : Ok
Module 0007, Controller Adaptive Parameters File (CAP)................ : Ok
Module 0008........................................................... : Ok
Module 0009, SMART Configuration File................................. : Ok
Module 000A, SMART Data File.......................................... : Ok
Module 000B........................................................... : Ok
Module 000D........................................................... : Ok
Module 0013, Disc Registry File (settings, security, etc)............. : Ok
Module 0015, BGMS File (Directed Offline Scan)........................ : Ok
Module 0016........................................................... : Ok
Module 0017........................................................... : Ok
Module 0019, Log File................................................. : Ok
Module 001A, Log File................................................. : Ok
Module 001B, Log File................................................. : Ok
Module 001C........................................................... : Ok
Module 001D, Physical Overlay File 0.................................. : Ok
Module 001E, Physical Overlay File 1.................................. : Ok
Module 001F, Physical Overlay File 2.................................. : Ok
Module 002A, Saved Mode Pages (HDD settings).......................... : Ok
Module 002B, R/W Operating Parameters (translator, etc)............... : Ok
Module 0033........................................................... : Ok
Module 0034, Packed CONGEN XML definition............................. : Ok
Module 0035, SMART Data............................................... : Ok
Module 003A........................................................... : Ok
Modules reading process completed
Reading HDD ID pages list...
Reading HDD ID pages...
ID Page 00............................................................ : Ok
ID Page 01............................................................ : Ok
ID Page 02............................................................ : Ok
ID Page 03............................................................ : Ok
ID Page 04............................................................ : Ok
ID Page 08............................................................ : Ok
ID Page 09............................................................ : Ok
ID Page 0A............................................................ : Ok
ID Page 0B............................................................ : Ok
ID Page 0C............................................................ : Ok
ID Page 0D............................................................ : Ok
ID Page 0E............................................................ : Ok
ID Page 0F............................................................ : Ok
Reading System Files to profile folder
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Brinks\ST3320613AS-CC2H-9SZ3HWZ0\Data\SABackup\SysFiles\
Copies : 0 1
Sys File FC000000(0), Reserved Defect Table (SA defect table)......... : Ok
Sys File FC000000(1), Reserved Defect Table (SA defect table)......... : Ok
Sys File FC001203(0).................................................. : Ok
Sys File FC001203(1).................................................. : Ok
Sys File FC002204(0).................................................. : Ok
Sys File FC002204(1).................................................. : Ok
Sys File FC003205(0).................................................. : Ok
Sys File FC003205(1).................................................. : Ok
Sys File FC004206(0).................................................. : Ok
Sys File FC004206(1).................................................. : Ok
Sys File FC00520B(0).................................................. : Ok
Sys File FC00520B(1).................................................. : Ok
Sys File FC00620C(0).................................................. : Ok
Sys File FC00620C(1).................................................. : Ok
Sys File FC00720D(0).................................................. : Ok
Sys File FC00720D(1).................................................. : Ok
Sys File FC345010(0), Primary Defect File (P-List).................... : Ok
Sys File FC345010(1), Primary Defect File (P-List).................... : Ok
Sys File FC34D01B(0), R/W Operating Parameters (translator, etc)...... : Ok
Sys File FC34D01B(1), R/W Operating Parameters (translator, etc)...... : Ok
Sys File FC34F026(0), Non Resident G-List............................. : Ok
Sys File FC34F026(1), Non Resident G-List............................. : Ok
Sys File FC350027(0).................................................. : Ok
Sys File FC350027(1).................................................. : Ok
Sys File FC355100(0), Physical Overlay File 0......................... : Ok
Sys File FC355100(1), Physical Overlay File 0......................... : Ok
Sys File FC356101(0), Physical Overlay File 1......................... : Ok
Sys File FC356101(1), Physical Overlay File 1......................... : Ok
Sys File FC357102(0), Physical Overlay File 2......................... : Ok
Sys File FC357102(1), Physical Overlay File 2......................... : Ok
Sys File FC358103(0).................................................. : Ok
Sys File FC358103(1).................................................. : Ok
Sys File FC359104(0).................................................. : Ok
Sys File FC359104(1).................................................. : Ok
Sys File FC35A105(0).................................................. : Ok
Sys File FC35A105(1).................................................. : Ok
Sys File FC35B106(0).................................................. : Ok
Sys File FC35B106(1).................................................. : Ok
Sys File FC35C107(0).................................................. : Ok
Sys File FC35C107(1).................................................. : Ok
Sys File FC35D108(0).................................................. : Ok
Sys File FC35D108(1).................................................. : Ok
Sys File FC35E109(0).................................................. : Ok
Sys File FC35E109(1).................................................. : Ok
Sys File FC35F10A(0).................................................. : Ok
Sys File FC35F10A(1).................................................. : Ok
Sys File FC36010B(0).................................................. : Ok
Sys File FC36010B(1).................................................. : Ok
Sys File FC36110C(0).................................................. : Ok
Sys File FC36110C(1).................................................. : Ok
Sys File FC36210D(0).................................................. : Ok
Sys File FC36210D(1).................................................. : Ok
Sys File FC363110(0).................................................. : Ok
Sys File FC363110(1).................................................. : Ok
Sys File FC37518A(0), Disc Registry File (settings, security, etc).... : Ok
Sys File FC37518A(1), Disc Registry File (settings, security, etc).... : Ok
System Files reading process completed
Reading loader data to folder (LDR)
Scanning LOD files...
Reading ROM...
ATA, DT
Parsing container segment....... Flash ROM image
Segment: BOOTFLOADER
Parsing segment....... BOOTFLOADER
End parsing segment... BOOTFLOADER
Segment: SHAREDFW
Parsing segment....... SHAREDFW
End parsing segment... SHAREDFW
Segment: NONREDN_CNT_0
Parsing container segment....... NONREDN_CNT_0
Segment: ADP_SERVO_DIR
Parsing segment....... ADP_SERVO_DIR
End parsing segment... ADP_SERVO_DIR
Segment: CAP
Parsing segment....... CAP
End parsing segment... CAP
Segment: RAP
Parsing segment....... RAP
End parsing segment... RAP
Segment: SAP
Parsing segment....... SAP
End parsing segment... SAP
Segment: SFW
Parsing segment....... SFW
End parsing segment... SFW
Segment: SHELL
Parsing segment....... SHELL
End parsing segment... SHELL
End parsing container segment... NONREDN_CNT_0
Segment: BOOTFW_CONT_0
Parsing container segment....... BOOTFW_CONT_0
Segment: BOOTFW_DIR
Parsing segment....... BOOTFW_DIR
End parsing segment... BOOTFW_DIR
Segment: GENERAL_DATA
Parsing segment....... GENERAL_DATA
End parsing segment... GENERAL_DATA
Segment: IAP
Parsing segment....... IAP
End parsing segment... IAP
Segment: BOOTFW
End parsing container segment... BOOTFW_CONT_0
Segment: BOOTFW_CONT_1
Parsing container segment....... BOOTFW_CONT_1
Segment: BOOTFW_DIR
Segment: IAP
Segment: BOOTFW
End parsing container segment... BOOTFW_CONT_1
End parsing container segment... Flash ROM image
reading file FC355100...
Importing: Overlay ID = 00
reading file FC356101...
Importing: Overlay ID = 01
reading file FC357102...
reading file FC358103...
Importing: Overlay ID = 04
reading file FC359104...
Importing: Overlay ID = 05
reading file FC35A105...
reading file FC35B106...
LOD.0(DFW.0)...
reading file FC00620C...
Disk FW
Segment: CUSTFW
Parsing segment....... CUSTFW
End parsing segment... CUSTFW
Image Info
Image size............... : 921600
QNR Revisions:
Flash ROM image.......... : 0
CODE info
Bank 0
ProdType................. :
Controller FW Rev........ : 11171841
Customer Release......... : CC2H
Changelist............... : 00126748
Build date / time........ : 11/17/2008 6:41:36 PM
Package Global ID........ : 00410638
Package Builder ID....... : OG
Build Rev................ : 00
Package Rev.............. : CG0H0H
Pkg P/N.................. : 100546649
Servo FW................. : D0C4 / ---- / ---- / ----
Package Version.......... : BR140D.CCD2.CG0H0H.CC2H
Pkg CFW Ver.............. : BR14.CCD2.00126748.OG00
Appending: Disk FW / CFW Overlay
Appending overlays...
LOD.1(DFW.1)...
reading file FC00720D...
Disk FW
Segment: CUSTFW
Image Info
QNR Revisions:
CODE info
Bank 0
Backup of service information completed
Test : Reading System Files
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Brinks\ST3320613AS-CC2H-9SZ3HWZ0\Data\SysFiles\
Copies : 0
Sys File FC342001(0), Read Adaptive Parameters File (RAP)............. : Ok
Sys File FC34300E(0), Performance Parameter File (PPF)................ : Ok
Sys File FC34400F(0), Drive Information File (DIF).................... : Ok
Sys File FC346011(0).................................................. : Ok
Sys File FC348012(0).................................................. : Ok
Sys File FC349013(0).................................................. : Ok
Sys File FC347014(0).................................................. : Ok
Sys File FC34A015(0).................................................. : Ok
Sys File FC34E01C(0).................................................. : Ok
Sys File FC351028(0).................................................. : Ok
Sys File FC34B02F(0), Servo Adaptive Parameter File (SAP)............. : Ok
Sys File FC308030(0).................................................. : Ok
Sys File FC309031(0).................................................. : Ok
Sys File FC30A032(0).................................................. : Ok
Sys File FC30B033(0).................................................. : Ok
Sys File FC30C034(0).................................................. : Error
Error : HDD Redynes timeout (10000)
Sys File FC30D035(0).................................................. : Error
Error : Operation aborted
Terminated by user
System Files reading process terminated
******************** 5/9/2024 2:14:50 AM ********************
Family ID: 2D
Then press OK!
Tech Key...
Media Cache
ID Len
8 4800
B 1000
D 160
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
33 4576
35 26 SMART Data
3A 4
ROM:
ID MemOffs Len
602BE00 4096
total 8192
RAM:
ID MemOffs Len
602BE00 4096
total 8192
ATA(indirect)
ErrorHDD Redynes timeout (10000)
Soft reset.............................. : Ok
Result.................................. : Error
Reading DT to profile folder
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Brinks\ST3320613AS-CC2H-9SZ3HWZ0\Data\SABackup\CPDir\
HDD Redynes timeout (10000) 00 / 00
F3 7>F 3 7
 Post subject: Re: Brinks on the Brink - Pls salvage
PostPosted: May 10th, 2024, 4:01
This family doesn't have MC, so it's not that.
If you reached to a point that you can image in DE, did you image head by head?
PostPosted: May 10th, 2024, 5:37
Hi northwind Thanks
yes I tried since data size is small (aprox 20 GB) but drive starts clicking suddenly and becomes busy , I was worried that this might result in complete head failure.
So I tried to disable SMP flags and make drive more efficient in SA reading . I will give it a try again by increasing jump sectors
PostPosted: May 10th, 2024, 23:30
Disk is clicking continuously and is not coming on terminal , I think heads are getting close to complete failure .
My only concern is heads should be the root cause and not anything else like SA or system file corruption.
From head resistance can we blame heads ?
PostPosted: May 11th, 2024, 7:31
Clicking and spin down?
PostPosted: May 12th, 2024, 8:09
Hi northwind , Happy Weekend
Thanks for responding.
Yes when powered while entering utility it does not click but when tried to read ID or while performing any activity it starts clicking but does not spin down.
I am worried whether my diagnostics itself could be wrong ,I am mistaken some unknown reason for clicking as head crash.
PostPosted: May 13th, 2024, 2:37
Can I take a look?
PostPosted: May 13th, 2024, 5:53
northwind wrote:
Can I take a look?
Hi Thanks a lot I will love to take control of this case by most authoritative technician .This case is ultra low cost , I will prefer a business job where I can payback for your time and efforts.
Can you pls suggest something I can try
PostPosted: May 13th, 2024, 8:15
Update
While entering utility I have given path of earlier saved system files & now disk has stopped clicking for some time but begins later. I am checking matching pcb , I suspect something could be wrong in pcb as well ,just to rule out possibility.
PostPosted: May 13th, 2024, 9:01
I mean if I can take a look for free...
PostPosted: May 13th, 2024, 21:14
Good Morning.
Thank You so much .Pls. pm me your free time I will give you access. :-D
Users browsing this forum: Google [Bot] and 72 guests
cron
