 Post subject: Can the sector count in a FAT32 partition be odd number?
PostPosted: May 16th, 2024, 4:10
I create a 256MB partition on hard disk. The format it to FAT32, with 4096 cluster size.
THen I check the Boot sector of the partition, and find the the following parameters:
Sector count: 530145
Reversed Area Size: 38
FAT Count: 2
FAT Size: 517
Sector per Cluster: 8
In such a case, (530145 - 38 - 517 * 2) is not a multiply of 8 sectors. Is that correct for a FAT32 partition?
 Post subject: Re: Can the sector count in a FAT32 partition be odd number?
PostPosted: May 17th, 2024, 13:29
NTFS also has an extra sector, at least for MBR partitions.
https://thestarman.pcministry.com/asm/mbr/NTFSBR.htm
"Total Sectors (in the Volume) will always be 1 sector less than the total number of sectors in the volume's partition table entry, because the NTFS "Backup Boot Sector" is not considered part of the NTFS Volume."
Users browsing this forum: No registered users and 51 guests
