 Post subject: My Book Duo Recovery
PostPosted: March 30th, 2024, 6:08
I'm trying to recover a My Book Duo (the older rounded shape one), the unit was kicked, both drives got a 99% recovery.
I know the bridge board runs encryption, but when I put the two clone drives back into the unit it doesn't recognise the RAID 0 configuration and just wants to set it up again.
Do the exact same model drives need to go back in the unit, or can any WD drive do? And does the encryption key stored in the original drive's firmare need to transplanted into the clone drives?
 Post subject: Re: My Book Duo Recovery
PostPosted: March 30th, 2024, 14:45
Assuming you don't get any answer to your questions, I would ...
1/ dump the SPI flash on the bridge PCB.
2/ examine the partition metadata on each drive to see whether there is a reserved area at the end of the UA (for use by the bridge firmware).
3/ scan the OS partitions for HDD serial numbers or model numbers or WWNs.
PostPosted: May 28th, 2024, 11:31
From UFS Explorer Pro v10.4 handles the decryption of the My Book Duo. I recommend the software, it is excellent.
Regards,
John
0161 408 4857
PostPosted: May 28th, 2024, 12:32
Recommand UFS Explorer :good:
PostPosted: June 19th, 2024, 11:56
First, are your sure that your MyBook Duo has been configured in RAID 0?
It would be an absurd choice for such a device.
Are you sure it is not in RAID 1 (mirror).
Did you check it with an Hex editor?
Users browsing this forum: No registered users and 85 guests
