Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate 9B V11 family firmware diagnostics
PostPosted: May 28th, 2024, 4:35
Disk Solution wrote:
I can look it online PM me. Looks like defects lists, 1 NGlist defect enough to multifunction full drive.
posidon wrote:
Can someone pls. take remote control to update sysfile 93 as I have given up now & about to return it as unrecoverable.
Hi Thanks Disk Solution ,
Will update you via PM
PostPosted: May 28th, 2024, 4:37
Thanks a lot Disk Solution. will update you.
PostPosted: May 28th, 2024, 5:11
pepe wrote:
fw does not support writing sysfile thru terminal.
you need to write over ata.
I am wondering if sysfiles can be only read from terminal & cannot be written by ATA indirect then PC3K will not be able to update sys file 93 .How super gurus will write in this case ? Do proprietory tools more powerful than pc3K really exists ?
PostPosted: May 28th, 2024, 5:23
indirect should work as far as i recall, but you need to properly init the util, have it parse sysfile tables, otherwise you get LED faddr 9039 because of file descriptor mismatch.
i am unsure coz i rarely write anything to SA, prefer to preserve original state.
PostPosted: May 28th, 2024, 11:13
As a seagate expert you & doomer's words are precious & beyond even pc3k's capabilities. But then as a popular belief to disable background scanning we have alter SA (sys 93 smp)
PostPosted: May 28th, 2024, 12:44
@posidon, can you access the data area now?
PostPosted: May 28th, 2024, 23:54
Good Morning fzabkar
I just can't believe how accurate diagnostic as well as remedy you have given based on few snapshots & terminal without actual checking.
Yes disk has given clear sector access , I could create head map without disk losing ready ness .
Head 2 seems to be healthy with aprox 10MB/sec read speed while other heads are slow , but I think following are the reasons -
1) I am not initializing disk properly - when to power on & unlock
2) Sys file 93 still unpatched.
3) Other files might need correction in order to smooth reading.
I am not going to do anything (not even smp patch) as I am not confident about my procedure. I am exporting acrep structure and based on customers selection trying to image only used sectors in order to further minimize any further mess.
Appreciate your technical expertise & help as with only few commands miraculously case is solved .At least it has saved my reputation as if I was about to return it as head weak /failed case.
Thank you for your help. :D :good:
PostPosted: May 30th, 2024, 7:00
Try issuing the following terminal commands at level T (WARNING: commands are Case SenSiTive).
F"READ_SPARING_ENABLED",0,22
F"WRITE_SPARING_ENABLED",0,22
F"OFFLINE_SPARING_ENABLED",0,22
F"DAR_ENABLED",0,22
F"DISABLE_IDLE_ACTIVITY",1,22
F"BGMS_DISABLE_DATA_REFRESH",1,22
F"ABORT_PREFETCH",1,22
F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
fzabkar your are real pro & genius
sysfile 93 is such a important file in rosewood family.
I have stuck while patching smp flags. Are these commands safe for every rosewood or seagate f3 model ?
If FW does not support terminal writing then how these commands issued alter sysfile 93 ?I have tried to find more information on these commands but not found its detailed desciption in manuals or F3 command booklet. A thread in hddoracle has extensive details of sysfile 93
Thanks for sharing vital knowledge :beer:
PostPosted: May 30th, 2024, 12:44
Information about these parameters can be found in a packed SA module. Module 0x34 is used in some models, but it may not be consistent across all of them.
Extracting Congen XML data from Seagate F3 SA mod 34:
http://www.hddoracle.com/viewtopic.php?p=20194#p20194
I have no idea whether any of these are safe to use in every F3 model.
PostPosted: May 30th, 2024, 13:15
This is the Congen documentation from a Rosewood resource dump:
http://www.hddoracle.com/download/file.php?id=5732
The commands that I chose were previously used to stabilise 7200.11 and 7200.12 models.
PostPosted: May 30th, 2024, 22:34
Very much informative a simple TTL adapter can fix this issue with few clicks which $10000 device can't. That's power of knowledge :-D :good:
PostPosted: May 30th, 2024, 23:53
Update to this case
Disk has become smooth & I have been able to disable background scanning . But I think some head specific tuning is a must to recover data as disk becomes busy while scanning some heads (head 3) while for some heads it gives 15MB/sec speed.
May be due to defective zones are the reason.
Terminal output has changed now -
CI0x3F
ATA St 50 Er 00 Op 3F A 0024000059BE, 0001 0001 0000
cyl=00056BCD
Op=0095
RW cmd 0002 req = 9C94 0000 0000 0000 0010 0000 0000 0000 0000 0000 2000 0007 3FFF 0007 2000 0007 0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000 FFFF FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
RW mode = 0000000000000000
BUF opts = 00000000
Resp=0001
RW cmd 0002 req = 9C84 0000 0000 0000 0010 0000 0000 0000 0000 0000 0000 0007 1FFF 0007 0000 0007 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
cyl=00056BCD
Op=0095 Resp=0001
RW cmd 0002 req = 9CF6 0000 0000 0000 0030 0000 0000 0000 0000 0000 6000 0007 BFFF 0007 6000 0007 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
cyl=00056BCD
Op=0095 Resp=0001
RW cmd 0002 req = 9D26 0000 0000 0000 0020 0000 0000 0000 0000 0000 C000 0007 FFFF 0007 C000 0007 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
cyl=00056BCD
Op=0095 Resp=0001
CI0x2FHostC0x3F
ATA St 50 Er 00 Op 2F A 0024000059BF, 0001 0001 0000
CI0xECHostC0x2F
ATA St 50 Er 00 Op EC A 0000002097DB, 0000 0000 000B
CI0x3F
HostC0xEC
RW cmd 0006 req = 0000 0000 0000 0000 0000 0000 D26D 1AF7 D0DB 3066 BF0D 004B 0002 0000 0080 0000 0006 0000 0001 0000 0020 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 3066D0DB
Di 25
cyl=00010058
Op=039B Resp=0001
cyl=00073F1C
Op=039B Resp=0001
cyl=0006E4DA
Op=039B Resp=0001
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
ATA St 50 Er 00 Op 2F A 0024000059BF, 0004 0004 0000
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
ATA St 50 Er 00 Op 2F A 0024000059BF, 0011 0011 0000
cyl=00056CED
Op=0095
RW cmd 0002 req = D5DE 0001 0000 0000 0002 0000 0000 0000 0000 0000 8404 0064 8803 0064 8404 0064 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
Resp=0001
HostC0
CI0x3Fx2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
ATA St 50 Er 00 Op 2F A 0024000059BF, 0009 0009 0000
cyl=00056CEE
Op=0095
RW cmd 0002 req = D6CA 0001 0000 0000 0001 0000 0000 0000 0000 0000 8404 0064 8603 0064 8404 0064 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
Resp=0001
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
RW cmd 0006 req = 0000 0000 0000 0000 0000 0000 D26D 1AF7 D0DB 3066 BF0D 004B 0002 0000 0080 0000 0007 0000 0001 0000 0021 0000 0000 0000
RW opts = 00011201
BUF opts = 3066D0DB
Di 25
cyl=00010260
Op=009B Resp=0001
cyl=0007A3B6
Op=009B Resp=0001
cyl=0001C237
Op=009B Resp=0001
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC0x2
CI0x3FF
CI0x2FHostC0x3F
Ho
CI0x3FstC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC0x
CI0x3F2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
Ho
CI0x2FstC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
Ho
CI0x3FstC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
HostC
CI0x2F0x3F
HostC
CI0x3F0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC
CI0x3F0x2F
CI0x2FHostC0x3F
Host
CI0x3FC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
H
CI0x2FostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
H
CI0x3FostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
RW cmd 0027 req = 2234 816D 2240 816D 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
Op=516F Resp=0001
RW cmd 0027 req = 23B4 816D 23C0 816D 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
Op=0501 symbol=0000 Resp=0001
RW opts = 00011201
BUF opts = 00000000
Op=0106 Resp=0001
RW opts = 00011201
BUF opts = 00000000
Op=0501 symbol=008F Resp=0001
cyl=00056B44
Op=0095
RW cmd 0002 req = 0898 0000 0000 0000 0001 0000 0000 0000 0000 0000 4800 002E 49FF 002E 4800 002E 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
Resp=0001
CI0x2FHostC0x3F
ATA St 50 Er 00 Op 2F A 0024000059BF, 0041 0041 0000
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
ATA St 50 Er 00 Op 2F A 0024000059BF, 0079 0079 0000
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
RW cmd 0006 req = 0000 0000 0000 0000 0000 0000 D26D 1AF7 D0DB 3066 BF0D 004B 0002 0000 0080 0000 0008 0000 0001 0000 0022 0000 0000 0000
RW opts = 00011201
BUF opts = 3066D0DB
Di 25
cyl=0000D352
Op=019B Resp=0001
cyl=0007FDB5
Op=019B Resp=0001
cyl=0006640B
Op=019B Resp=0001
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
Host
CI0x3FC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
Ho
CI0x3FstC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC0x2F
CI0x3F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
CI0x3FHostC0x2F
CI0x2F
HostC0x3F
CI0x3FHostC0x2F
CI0x2FHostC0x3F
HostC0x2F
RW cmd 0034 req = 0000 0000 0000 0000 0000 0000 D26D 1AF7 D0DB 3066 BF0D 004B 0001 0000 0080 0000 0009 0000 0001 0000 0023 0000 0000 0000
BF0D 004B 0002 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 3066D0DB
Op=012F Resp=0001
TCC:0025 EMCDataErr:00000014
Op=0101 Resp=0001 data=000003B5
Op=0101 Resp=0001 data=00000008
Op=0101 Resp=0001 data=00000000
Op=0101 Resp=0001 data=0000FFBC
Op=0101 Resp=0001 data=0000FFFB
Op=0101 Resp=0001 data=0000FE07
Op=0101 Resp=0001 data=00000002
Op=0101 Resp=0001 data=0000FE8D
Op=0101 Resp=0001 data=0000FFF9
RW cmd 0038 req = 0081 0000 0000 0000 5E8C 0003 0000 0000 8081 FFFF 6275 0003 0000 0000 0000 0000 0000 0000 03E8 0000 27C0 0009 0000 0000
FFFF FFFF FFFF FFFF FFFF FFFF 0000 0000 BF0D 004B 0002 0000 0080 0000 0006 0000 000A 0000 1770 0000 4650 0000 8CA0 0000
RW opts = 00011201
BUF opts = FFFF8081
IDLE1
RW cmd 0006 req = 0000 0000 0000 0000 0000 0000 D26D 1AF7 D0DB 3066 BF0D 004B 0002 0000 0080 0000 0009 0000 0001 0000 0023 0000 0000 0000
BF0D 004B 0001 0000 0080 0000 0000 0000 0174 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 3066D0DB
Di 25
cyl=000151EF
Op=029B Resp=0001
cyl=0007E097
Op=029B Resp=0001
cyl=00043E74
Op=029B Resp=0001
RW cmd 0006 req = 0000 0000 0000 0000 0000 0000 D26D 1AF7 D0DB 3066 BF0D 004B 0002 0000 0080 0000 000A 0000 0001 0000 0023 0000 0001 0000
RW opts = 00011201
BUF opts = 3066D0DB
Di 25
cyl=0001B5DD
Op=039B Resp=0001
RW cmd 0006 req = 0000 0000 0000 0000 0000 0000 D26D 1AF7 D0DB 3066 BF0D 004B 0002 0000 0080 0000 000B 0000 0001 0000 0023 0000 0002 0000
RW opts = 00011201
BUF opts = 3066D0DB
Di 25
cyl=0005A01F
Op=009B Resp=0001
PostPosted: May 31st, 2024, 4:32
I have further observed that I cannot refresh utility status or disk is not initialized properly if system file reading is set to terminal , in indirect reading mode UA /SA ,FW can be read instantly. I think it has something to do with system file related issue & not necessarily head 3 ( head 3 is reading 15kb/sec now & disk loses readyness )
PostPosted: May 31st, 2024, 4:57
Head 3 is having varied reading speed ( 10kb/s to 20MB/s ) It might have become weak on particular zones .
PostPosted: June 2nd, 2024, 4:05
Thanks to all of you particularly fzabkar & pepe I have concluded this case successfully.
I tried my best but was forced to disable Head 3 & recover data covered by other heads.
But it was great learning which will be useful for future . I would be happy to know whether Heads can be tuned on fw level in pc3k .
Thank you .
PostPosted: June 5th, 2024, 17:03
I notice that there is this field in Module 0x34 (Congen definitions) of a Rosewood A5:
<field idx="1205">
   <name>DISABLE_CORRECTION</name>
   <grp>RWErrorRecovery</grp>
   <desc>
      <line>1 = Only on-the-fly ECC correction shall be applied.</line>
      <line>0 = Maximum ECC correction shall be applied if correction is possible.</line>
   </desc>
   <bitoffset>0</bitoffset>
   <bitlen>1</bitlen>
   <defaultval>0</defaultval>
   <parent>1000</parent>
</field>
Perhaps the following command at Level T will speed up the reading? I don't know if it is safe, though.
    F3 T>F"DISABLE_CORRECTION",1,22
PostPosted: June 5th, 2024, 23:35
<field idx="1205">
   <desc>
   </desc>
   <bitlen>1</bitlen>
</field>
Thanks fzabkar
Anyway I have given up further work & asked customer the same so I will be happy to test & ready to accept whatever outcome comes .At least It will be clear for future cases as again I will not be able to take chances for new cases while I can take chance for this.
I still have patient drive & will update outcome.
PostPosted: June 6th, 2024, 5:26
After issuing command , I got following output
I can't interpret what it means. But It has not improved reading. I think original issue could be in weak head 3 or defect list ,all I have done is work on sys file 93 I don't know how to repair other files and there role also.
May be in future cases I will go beyond sysfile 93 , I will have to learn about tec /sedu as well.
Thanks fzabkar it was all possible because of you only.
RW cmd 0027 req = 2264 816D 2270 816D 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00011201
BUF opts = 00000000
Op=516F Resp=0001
RW opts = 00011201
BUF opts = 00000000
RW opts = 00011201
BUF opts = 00000000
Op=0106 Resp=0001
RW opts = 00011201
BUF opts = 00000000
Drive AMPS Configuration has been modified from compiled defaults.
Drive must be re-initialized to controller firmware defaults by re-downloading controller firmware
DO NOT SHIP WITHOUT FIRST RE-DOWNLOADING CONTROLLER FIRMWARE OR RESETTING TO DEFAULTS!
RW cmd 0042 req = 0001 0000 3245 8052 D555 004F 0801 0808 C808 004C 1400 0480 E200 816A A8B0 8052 A870 8052 E228 816A 7131 004E 0100 0017
0000 0000 D763 001A A900 8052 0080 0000 A9C8 8052 013B 0000 0000 0000 A908 8052 27A9 0055 A908 8052 209C 816D A908 8052
RW opts = 00011201
BUF opts = 004CC808
cyl=00056CED
Op=00A5
RW cmd 0002 req = D5DE 0001 0000 0000 0002 0000 0000 0000 0000 0000 CA00 002D CDFF 002D CA00 002D 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00028201
BUF opts = 00000000
Resp=0001
cyl=00059451
Op=01A5
RW cmd 0002 req = E6A1 0003 0000 0000 0002 0000 0000 0000 0000 0000 CA00 002D CDFF 002D CA00 002D 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00028201
BUF opts = 00000000
Resp=0001
cyl=00056CEE
Op=00A5
RW cmd 0002 req = D6CA 0001 0000 0000 0001 0000 0000 0000 0000 0000 6218 0019 6417 0019 6218 0019 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00028201
BUF opts = 00000000
Resp=0001
cyl=000593AF
Op=01A5
RW cmd 0002 req = 3722 0003 0000 0000 0001 0000 0000 0000 0000 0000 6218 0019 6417 0019 6218 0019 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00028201
BUF opts = 00000000
Resp=0001
cyl=00056CEE
Op=00A5
RW opts = 00028201
BUF opts = 00000000
Resp=0001
cyl=000593AF
Op=01A5
RW opts = 00028201
BUF opts = 00000000
Resp=0001
(D) SATA Reset
RW cmd 0027 req = 2270 816D 2288 816D 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
RW opts = 00028201
BUF opts = 00000000
Op=0C01 Resp=0001Byte:0092: Bit:0, DISABLE_CORRECTION = 1
F3 T>
PostPosted: June 6th, 2024, 5:41
-slip list is ok if you can read other surfaces.
-H3 can read better at some areas, so it is likely not very weak.
-One thing remains: surface. if surface is damaged, you cannot expect thunder speed with whatever settings. However, if you set block size to 1, jump size to 1 and a bit higher timeouts, you can see the pattern of blacks and evaluate. Changing read retries in RWErrorRecovery group has no effect in most of the cases but there are other unofficial ways to limit retry count, speeding up the process a bit. But it won't be close to the speed of good areas in any case.
Of course, the data you get will have errors, so its value will be questionable anyway.
PostPosted: June 6th, 2024, 8:13
Thanks pepe for important insight .
Yes surface degradation of platter covered by head 3 might be there . What is the reason disk loses ready ness & becomes busy ? Is it good idea to read sectors using active pc3000 utility ?
I am observing more and more cases coming now are having head related issues and pure firmware cases are getting rare (seagate is most popular brand here in india .Most of the 500GB/1TB/2TB disks are 6+ years old and are having head /platter issues .Recovery is getting complex day by day .SMR /SED have added more complexity to newer drives.
I will try changing read retry settings
Thank you
