 Post subject: SP S55 - SATAFIRM S11
PostPosted: May 28th, 2024, 14:52
Hi i have Silicon Power S55 with SATAFIRM S11 Error
im trying to boot this drive in save mode via MRT (short two pins on PCB) but disk is not ready
what am I doing wrong ?
 Post subject: Re: SP S55 - SATAFIRM S11
PostPosted: May 29th, 2024, 1:20
Try to not short anything, power on the drive and enter the utility...does it work? Or it goes to BSY state?
www.datasave.ro
PostPosted: May 29th, 2024, 3:49
pins not shorted
and nothing more, unfortunately
PostPosted: May 29th, 2024, 4:11
Check the 3 supply voltages. Perhaps a missing NAND Vcc supply might produce the same symptom???
PostPosted: May 30th, 2024, 1:33
Ok. Show us the same screenshots but this time with pins shorted.
www.datasave.ro
PostPosted: August 26th, 2025, 14:53
im back to topic
wittout shorting i see this
PostPosted: August 26th, 2025, 16:15
Create the translator at this point and in the DE use "Read form active MRT Utility" as normal.
VEXUS Data Recovery
PostPosted: August 27th, 2025, 11:01
100% sucess, thanks a lot !
Users browsing this forum: Majestic-12 [Bot] and 10 guests
