 Post subject: Very old Conner CT210 problem
PostPosted: May 15th, 2024, 10:06
Hello everybody,
I have here a very old Conner HDD model CT210 (10.2GB).
It doesn't spin up, so I suspect bad PCB.
As donor, I have a CT210 but not from Conner but from ExcelStor (that acquired Conner, I think). PCB is VERY similar, but FW is different... (I attach pics).
With donor PCB, Conner HDD spins up but makes bad noise (continous TRRRRRRRRR) with heads.
I opened it in clean room and heads SEEM ok.
There is something to transfer from patient PCB to donor PCB or something I can try with this vintage HDD?
Simone
pics:
https://ibb.co/LvDXrXz (Patient HDD)
https://ibb.co/89Sh2hd (Patient PCB)
https://ibb.co/JrKbdKj (Donor HDD)
https://ibb.co/0QZzsQH (Donor PCB)
 Post subject: Re: Very old Conner CT210 problem
PostPosted: May 15th, 2024, 12:42
U4A and U5 are parallel flash.
PostPosted: May 15th, 2024, 13:23
I notice that the 8-pin IC (part marking?) has a dimple. Perhaps it is damaged?
Here is the brief datasheet for a similar (?) MCU:
L5510 / AIC-5465-DIE, STMicroelectronics, HIGHLY INTEGRATED, AUTOMATED SINGLE-CHIP DRIVE MANAGER AND DISK DRIVE CONTROLLER, 2.5V core, 3.3V logic, QFP-208:
https://pdf1.alldatasheet.net/datasheet-pdf/download/103639/STMICROELECTRONICS/AIC-5465-DIE.html
I suspect that the Vio (3.3V) and Vcore (2.5V) voltages are provided by the transistors at U12 and Q1 (right hand edge of PCB).
MX29F100BTC, Macronix, 1Mbit [128Kx8/64Kx16] CMOS FLASH MEMORY, 5V, TSOP-48:
https://www.datasheetarchive.com/datasheet?id=2939697e74bfbe5cb9f894c09453552e9260b2&type=M&term=MX29F100
M29F102BB, STMicroelectronics, 1 Mbit (64Kb x16, Boot Block) Flash Memory, 5V, TSOP40:
https://pdf.datasheetcatalog.com/datasheet/SGSThomsonMicroelectronics/mXyyqus.pdf
FDC6561AN, Dual, N-Channel, Logic Level, POWERTRENCH MOSFETs, 2.5A, 30V, 95mOhm RDSon, marking 561 / 561x, TSOT23-6:
https://www.onsemi.com/pdf/datasheet/fdc6561an-d.pdf
PostPosted: May 15th, 2024, 13:42
Could U11 constitute a supply for the preamp?
The DRAMs ...
SM81C256K16CS-35, Silicon Magic, 256K x 16 EDO DRAM, 5V, 66 / 83 / 100 MHz, TSOP-44:
https://www.ic72.com/pdf_file/s/11555.pdf
IS41C16256-35T, ISSI, 256K x 16 (4-MBIT) DYNAMIC RAM with EDO PAGE MODE, 5V, TSOP-40:
https://www.mouser.com/catalog/specsheets/issi_IS41C16256.pdf
PostPosted: June 3rd, 2024, 14:57
Doesn't spin up as in theres no attempts to spin or the motor attempts to spin up, but can't?
Users browsing this forum: No registered users and 104 guests
