 Post subject: Seagate Barracuda ST2000DM001 (2000GB)
PostPosted: June 7th, 2024, 4:13
I hope it's the right place where ask, if not I apologize
I've a Seagate Barracuda ST2000DM001 (2000GB) and suddenly the PC stopped to recognize it
I've tried to replace the logical board with an identical one and it's recognized as a 8TB disk, then I've swapped the bios chip from the old PCB to the new one but again the disk is not see by the system
Can the BIOS be corrupted? I've just purchased a CH341 CH341A programmer (not yet delivered) and will try to read the old bios chip, in the meantime have you any suggestion?
For your information, with both bios chip I can't hear the disk spinning
Thanks in advance and regards
 Post subject: Re: Seagate Barracuda ST2000DM001 (2000GB)
PostPosted: June 7th, 2024, 4:31
I've just checked, the initial spinning sound is present
PostPosted: June 7th, 2024, 13:56
If the drive is spinning, then it's unlikely to be a PCB fault.
PostPosted: June 7th, 2024, 18:20
Molto probabilmente la pcb originale non è affatto guasta, e la rom nemmeno.
Hai controllato se i contatti HDA sulla pcb sono per caso ossidati (anneriti)?
Magari posta una foto, se è così prova a pulirli passandoci sopra con una gomma da cancellare, non troppo energicamente.
Most likely the original pcb is not faulty at all, and neither is the rom.
Have you checked whether the HDA contacts on the pcb are oxidised (blackened) by any chance?
Post a pic, if they are oxidised then try cleaning them by running an eraser over them, not too vigorously.
My firmware database:
PostPosted: June 8th, 2024, 1:27
Grazie per il suggerimento, proverò a pulire i contatti e vi faccio sapere. Quello che non mi torna è che con una PCB nuova il sistema mi dice che il disco esiste ma con un size errato probabilmente per il bios con cui è arrivato mentre con la PCB originale il diagnostico è nessun disco. A breve pubblico anche la foto, grazie ancora
Thanks for the tip, I will try to clean the contacts and I will keep you in the loop. What I dont understand is: with a new PCB the HD is recognized with a wrong size maybe for the new bios chip but with the original PCB no disk is detect. I will post the PCB image soon, thank in advance
PostPosted: June 8th, 2024, 6:52
Quando usi la rom originale, si sentono almeno i piatti che ruotano o resta tutto in silenzio?
Se rimane tutto completamente in silenzio quando c'è la rom originale, potrebbe essere stata attivata la funzionalità PUIS (Power-Up In Standby).
Se è così, prova a disattivarla usando qualche tool tipo HDAT2 o MHDD.
When you use the original rom, can you at least hear platters spinning or does everything remain silent?
If everything remains completely silent when using the original rom, the PUIS (Power-Up In Standby) feature may have been activated.
If so, try deactivating it using some tool like HDAT2 or MHDD.
PostPosted: June 8th, 2024, 13:27
Sorry, i missed that !
Well, i think platter are stucked.
PostPosted: June 11th, 2024, 3:04
I post here a little update
I took the original PCB and I've mounted back the original BIOS chip
The HDA contacts was a bit oxidized and I cleaned them with an eraser and isopropyl alcohol. When I put the disk in the system the initial spinning sound can be heard but the diagnostics is always the same: No hard disk found
I've also check with a digital multimeter most of resistors, diodes and fuses and I cant find any obvious problem
As I said, with a new identical PCB but with a different BIOS chip, the system recognize the disk but with a wrong size
In attach the PCM image
Thanks in advance
Users browsing this forum: No registered users and 82 guests
