Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: PFconcept 1GB USB stick - partition turned into RAW
PostPosted: June 8th, 2024, 10:05
Another extremely weird behavior I noticed, after deleting the partition, it now goes back and fourth from no partition to having an partition, but not formatted. Its definitely beyond repair.
PostPosted: June 9th, 2024, 14:17
Heres something interesting I found after using validrive. It looks like it only validated 16kb of storage space. Maybe the controller died?
Report.docx [18.28 KiB]
Downloaded 410 times
PostPosted: June 9th, 2024, 16:35
ValiDrive is extremely clumsy as is demonstrated by its report. Just another of SG's f*ckups
The graph does not at all support the conclusion.
PostPosted: August 3rd, 2024, 6:30
But that tool would work on confirming chinesium drive sizes?
And forgot to mention the drive went corrupt after being dropped from my desk (it was from around 80 centimeters). I guess the problem will be the controller or the flash itself (its unbranded with "HVNE4F4 1025" written on it).
PostPosted: August 7th, 2024, 9:07
Banned User
Try cloning the drive with DMDE, then run R-Studio or Rundelete on the clone. If you're still getting corruption, cooling the NAND chip with freeze spray or measuring its voltage might help.
PostPosted: August 8th, 2024, 9:13
But whats the point of running R-studio on the cloned image? I couldn't find any options to repair corrupted files under rstudio and rundelete. Already measured the voltages for controller and NAND and tried freezing, cooling with compressor and putting a gpu heatsink with a fan on the NAND with less corrupted files, but still corrupted nonetheless.
PostPosted: December 9th, 2024, 9:01
What I found weird is that the drive gets unplugged on sector 713,600 when using LLF tool from here. And it always reverts the partition to RAW.
PostPosted: December 9th, 2024, 12:00
Still beating this dead horse?
PostPosted: December 10th, 2024, 14:57
I tired it just for fun but I still don't know whenever its the controller or nand. Probably I will find out someday, someday...
PostPosted: December 10th, 2024, 16:26
If it drops while scanning, it's the NAND.
Users browsing this forum: Google [Bot] and 116 guests
