 Post subject: Seagate - Samsung M8E - ST1000LM024 Diagnostics
PostPosted: June 15th, 2024, 3:21
This samsung m8E family disk gives fw errors while initializing .
in DE scratching sound comes while reading Head 2 & disk goes to busy state , while I could read using Head 0,1 & 3.
utility head test shows Head 2 ok but gives errors for Head 3
Is this some kind of FW issue as all modules under head 0 are fine.
 Post subject: Re: Seagate - Samsung M8E - ST1000LM024 Diagnostics
PostPosted: June 15th, 2024, 6:38
Initial diagnostics here would have been taking heads out for inspection under microscope.
And most likely change them before powering the drive.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: June 16th, 2024, 5:56
Thanks digisupport
That is right approch ,customer in this case wants only single database file & do not want to to spend money for head transplant.
I want to give it a try on FW level first . If I could conclude whether head2 is indeed bad then there will no option.
