Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: ST1000LM024 is spinning but not reading nor detecting!
PostPosted: June 23rd, 2024, 1:50
PuTTY and pl2303 usb to serial
PostPosted: June 23rd, 2024, 11:15
I don't recognise the problem in your last screenshot, but let the log run for a while. If you see "gray errors", they point to head problems. "1140" errors point to problems with specific sectors or firmware modules.
PostPosted: June 23rd, 2024, 23:57
Hi, i am very keen on the remedy and results you are getting on your search for the solution. Keep us posted.
PostPosted: June 24th, 2024, 5:21
Of course you have a problem with the heads.
And probably with the surface.
And who knows what else.
This hole didn't make itself...
PostPosted: June 24th, 2024, 9:37
WD My Book 25ED is too slow what should i've to do to recover all the data
PostPosted: June 24th, 2024, 10:39
206 delays detected on HDD Regenerator what I've to do for recovering all the data from the WD40EZRZ-00GXCB0 drive
PostPosted: June 24th, 2024, 11:03
First of all - stop using hddregenerator and other programs that unnecessarily load the disk.
Secondly - looking at what you are doing, seek professional help.
PostPosted: June 24th, 2024, 11:07
I'm a professional and seeking professional help from hdd guru :)
PostPosted: June 24th, 2024, 11:10
Anyway to speedup the drive :)
PostPosted: June 24th, 2024, 11:55
Really?
PostPosted: June 24th, 2024, 12:10
I mean not a data recovery professional but a computer professional and technician
PostPosted: June 24th, 2024, 12:15
A computer service is not a data recovery company, just as a data recovery company is not a computer service.
The problem in WD is most likely surface degradation, heads weak or the Relo List overflowing, but that's just a guess.
Any requests for help should include a snapshot of the current SMART if possible.
I don't know why this condition is omitted in forum posts...
PostPosted: June 24th, 2024, 12:47
Here You Go!
Don't you guys have a discord channel or irc channel??
PostPosted: June 25th, 2024, 1:36
this is a drive for a different topic...
Lukas has the point, don't mess with client drives without experience. There are several members from India able to take care of this drive with a bit more insight.
PostPosted: June 25th, 2024, 3:04
As I wrote, the device has problems with the surface (01, C5).
This may also be due to the degradation of the heads.
You can read SMART and the device can still be copied, so there is no problem with ReloList yet.
From a data recovery perspective, slow copying is better than no copy at all.
It is also possible that using hardware/software solutions will not achieve better results on original components.
PostPosted: June 25th, 2024, 3:43
So what should I do now?? Please help me!
PostPosted: June 25th, 2024, 4:27
Can you fix my devices through remote virtual here, flexible hub and team viewer
PostPosted: June 30th, 2024, 16:19
Please help me I'm on eng> what should I've to do
But same model hdd with no data and I want to refurbish it. I'll post the info after trying on this hdd. Please
PostPosted: July 2nd, 2024, 12:28
Please help me I need the data on this hdd I'm on eng> mode what should I do
PostPosted: July 8th, 2024, 4:21
Just holed it with my screw driver that's all :D
Users browsing this forum: No registered users and 83 guests
