 Post subject: WD40EZRZ-00GXCB0 Very Slow
PostPosted: June 24th, 2024, 11:26
Hi guys I need to recover all the data's from this drive. I've WD Pro Tool 6.0 anyway to recover the data using this tool. BTW all data's are showing perfectly but I cannot copy. Tried to extract the data with UFS Explorer Pro 10.5 but it was too slow it took 5 hours to copy some files. Any help :)
 Post subject: Re: WD40EZRZ-00GXCB0 Very Slow
PostPosted: June 24th, 2024, 11:49
As this is a reference for your professional service. Thank you!
PostPosted: June 28th, 2024, 20:30
this is a firmware issue you need tools like PC3K or MRT to fix this firmware issue
PostPosted: June 30th, 2024, 0:11
WD40EZRZ-00GXCB0
S/N: WD-WCC7K3FEU7FF
WD DASHBOARD Compatible Firmware Needed
To fix the slowness of the hard drive without pc3k
To update the firmware and recover from slowness! Would this be possible :?:
PostPosted: June 30th, 2024, 0:14
Or will niagara will help??
PostPosted: July 17th, 2024, 2:23
Will wdmarvel work for this issue??
I'm getting 4F10 state on wdmarvel for every actions
Users browsing this forum: No registered users and 90 guests
