 Post subject: HITACHI HDT721050SLA360
PostPosted: July 6th, 2024, 15:26
How to clear Reallocated Sectors count for this drive!
Thank you everyone
up loading photos
 Post subject: Re: HITACHI HDT721050SLA360
PostPosted: July 6th, 2024, 15:58
I don't see any reallocated sectors.
PostPosted: July 7th, 2024, 5:12
The caution ⚠️ message!
I tried to clear it with Victoria but there's no clear smart option after unscheduled refresh base. Could you please help me on this??
PostPosted: July 7th, 2024, 14:36
HGST HDDs support the Format Unit (F7h) command. This merges the G-list into the P-list. The command is data destructive.
PostPosted: July 8th, 2024, 4:17
Data Destruction is not an issue for this hdd coz its my hdd for learning purposes :)
How do I execute this??
What are the tools needed??
Is it a Terminal command??
This drive has sensor port only for iMac coz I removed this from an iMac!
PostPosted: July 8th, 2024, 9:50
I think Hugo or Niagara should be able to do it. The technical details of the command are described in HGST product manuals.
PostPosted: July 10th, 2024, 13:42
Hugo failed to format and erase
Niagara no option for usb only wincil, ahci, ata, serial what should I do??
PostPosted: July 10th, 2024, 14:23
Stop making your life difficult by interposing a USB bridge between the drive and the host. Use SATA mode.
PostPosted: July 11th, 2024, 10:27
Hugo and Niagara fails on Direct SATA Mode What Should I do??
PostPosted: July 11th, 2024, 13:35
https://hdd.by/victoria/ (Service -> HGST Vendor spec.)
Connect directly to the SATA motherboard.
Make an adapter for the power wire with a 5V and 12V switch.
To exit from frozen mode...
PostPosted: July 11th, 2024, 13:56
Now the hdd is undetected in windows and not spinning. This was the only hdd which saved all my business data. After niagara's codes. What should I do. This was a perfect hdd with some errors but was working perfectly. I restored all my data's from this hdd. I want to save this hdd. Please help
PostPosted: July 11th, 2024, 14:30
M041633n wrote:
Now the hdd is undetected in windows and not spinning...
May he rest in peace...
PostPosted: July 11th, 2024, 14:36
Why?? :?:
Any terminal connection to see the drive's terminal logs
PostPosted: July 11th, 2024, 18:25
Then...
I am the only one confused with the amount of posts by this user, and the commentary?
Dude, seriously... A SMART failing drive should not be trusted to save data. You've posted in a DR community, we don't care about restoring drives to 100% operation, we just recover data and then duplicate to a new storage media. You have to think, if the SMART data suggests a failure there is an underlining cause. Popping a head or clearing SMART does not fix the underlying problem - it's masking it.
PostPosted: July 11th, 2024, 23:55
Atleast I'll make it as a spare drive for temporary purposes! Like sharing movies and imaging purposes Please
PostPosted: July 13th, 2024, 11:32
For such purpose buying a new disk may be cheaper.
Users browsing this forum: Google [Bot] and 232 guests
