 Post subject: ST1000VM002-1CT162-500
PostPosted: July 8th, 2024, 8:19
How do I solve this error?
 Post subject: Re: ST1000VM002-1CT162-500
PostPosted: July 8th, 2024, 13:57
You can use PrtScn to capture the screen to your clipboard and then use Ctrl-V paste the clipboard contents into an image editor. Alternatively, use the Windows Snipping Tool to do the same.
PostPosted: July 8th, 2024, 14:37
Thanks but I don't have an internet connection. I'm doing this from my phone.
PostPosted: July 8th, 2024, 14:46
ISTM that there is a problem with file #28.
PostPosted: July 8th, 2024, 22:02
How do I fix that
And how do I get rid of this error
PostPosted: July 10th, 2024, 11:34
Same identical hdd (S) SATA Reset's Often in terminal. I cannot initialize the disk. If I initialize the disk in disk management the disk vibrates with grk grk effect but the disk spins fine and I get CRC error on disk management. Any help would be highly appreciated :) I even erased it with Seagate F3t.
PostPosted: July 10th, 2024, 12:53
Anybody??
PostPosted: July 12th, 2024, 1:18
M041633n wrote:
Anybody??
Does it have full firmware access? Some of those commands should be safe to run:
Disk Info
Head Check
Show Glist
Show Plist
Show Smart
Do they work? I wouldn't mess with the more advanced commands as you could damage it.
Zero Alpha: zeroalpha.com.au
PostPosted: July 15th, 2024, 10:57
I don't know how to access the firmware
But the commands are working!
PostPosted: July 15th, 2024, 11:00
What are these anyway??
PostPosted: July 15th, 2024, 15:29
https://www.google.com/search?q=0xC4030088
:o
PostPosted: July 15th, 2024, 19:38
What tool are you using?
Does the Drive have full correct ID?
Is this drive making clicking sounds?
PostPosted: July 16th, 2024, 4:17
1.F3 tool from hpwlab
2. What does a correct id mean or what's a id mean?
You mean the name of the hd in device manager??
3. No but at spin up! Other than this the drive does not show on my computers but formats OK with m commands but some m commands shows led error codes
PostPosted: July 17th, 2024, 19:48
Full id would be correct model, serial, firmware and capacity (1000gb) when its detected. It spins up clicks and spins down after its powered on?
PostPosted: July 17th, 2024, 23:45
Yup correct! It shows those info!
Nope! Its perfectly running without spinning down except it will not show up on the computer or disk management or the device manager. Before that I used to press Self Test Button on the Seagate F3 Tools by hpwlab it'll show up on this pc but it's not showing me now. Any special m commands would throw Led FAddr error codes and spins. I have to replug the SATA Power Connector to get to the F3
Terminal again.
PostPosted: July 18th, 2024, 3:42
Russian-language forum. There are topics specifically about HDD repair.
SG http://forum.ru-board.com/topic.cgi?for ... pic=5614#1
https://forum-ru--board-com.translate.g ... pto=wapp#1
WD http://forum.ru-board.com/topic.cgi?for ... pic=5642#1
Users browsing this forum: No registered users and 55 guests
