 Post subject: Zero write on a bad sector HDD, Freeze
PostPosted: July 14th, 2024, 4:11
Hi
i have a WD mypassport 4TB hdd which started to have bad sectors due to power surge,
simple recovering was making it to produce more bad sectors, so i used HDDsuperclone to recover data which it was very successfull.
now i'm trying to zero fill HDD before sending it to warranty ...
i used HD tune zero fill but it got stuck on bad sectors .
i'm looking for a software like HDDsuperclone which can handle bad sectors while writing zero into it.
HELP! :cry:
 Post subject: Re: Zero write on a bad sector HDD, Freeze
PostPosted: July 14th, 2024, 7:14
Just return it for a new one, no point chancing a doggy drive.
PostPosted: July 15th, 2024, 18:35
I don't have a solution to offer, perhaps there is some disk wiping software out there that does it already. But I noted it as a feature request for hddsuperclone: https://github.com/thesourcerer8/hddsup ... /issues/36
PostPosted: July 15th, 2024, 20:17
You could try using linux dd
sudo dd if=/dev/zero of=/dev/sdX bs=1M conv=noerror,sync status=progress
replace 'X' with your drive and it should zero fill it and skip bad sectors because of the conv=noerror,sync flag.
We have an inhouse app that solves this problem but I think playing around with different linux commands will achieve what you want. Depending on how bad your drive is you can give dd even more options like jumping and building a map.
Zero Alpha: zeroalpha.com.au
PostPosted: July 16th, 2024, 3:26
try formatting it with the provided wd util , this should set up a new encryption key, making old data unreadable instantly
PostPosted: July 19th, 2024, 7:34
thanks all, i finally managed to format it in HD tune SECTOR mode. and returned it to warranty.
Users browsing this forum: Google [Bot] and 218 guests
