 Post subject: WD easystore Recovery Unable to use PC3K
PostPosted: July 27th, 2024, 6:13
I have got a 4TB WD easystore USB when connected to windows /linux live it is unable to mount .In pc3k also utility does not start as windows is unable to mount it.
I tried to run r-studio emergency but it also failed. Is there any way to gain access ? DFS DOS shows a subfolder but it is not a data recovery tool.
 Post subject: Re: WD easystore Recovery Unable to use PC3K
PostPosted: July 28th, 2024, 19:18
Is the drive working correctly? Do you have full access to the data area? What does the data area look like in hex? Does it have encryption?
Zero Alpha: zeroalpha.com.au
Find Cheap Donor Drives App: https://www.zeroalpha.com.au/donor-drive-app Updated February 2026
PostPosted: July 28th, 2024, 23:45
Disk is not getting correctly mounted by windows (may be WD smartware corruption ) or bad sector or FW corruption.
So I cannot open it in PC3K as well . The only solution seems to be to get unlocked PCB's and do the recovery.
Unfortunately I don't have this pcb and only 1GB of personal photos to be recovered.
Considering payout its not worth to buy pcb as client is not going to pay even 5% cost.
PostPosted: July 29th, 2024, 8:02
It likely works with Deepspar USB Stabilizer 5G and 10G.
Recovery Force Data Recovery
PostPosted: July 30th, 2024, 1:48
Oh great , Deepspar would have done the job without manual intervention bypassing WD smartware as well?
Deepspar is definately my list of future purchases.
PostPosted: July 30th, 2024, 7:34
Stabilizer prompts with enter password and gives the option to remove it.
Just had one of these old drives a couple weeks ago...even PC3K portable III USB wouldn't load the drive and the drive wouldn't even spin with a SATA pcb after rom transfer.
Connected to stabilizer-10G and imaged with R-studio.
Users browsing this forum: No registered users and 197 guests
