 Post subject: "VSC ERR STATIC FILE INVALID"
PostPosted: July 24th, 2024, 15:58
I have WD20SDRM-59A4DS1
ROM F/W 0076008M
PCB 810003 type C
With SATA PCB 800065, I can get a full ID and access to all MDL, all heads are good
but with the original PCB and SATA adapter, I get no ID
so after blocking SA and using a loader backed up using the 80065 PCB, I got errors
Cache ovl(10) data uploading............ : Ok
Permanent ovl (11) data uploading....... : Ok
Static module reading error Device Error Detected: "VSC ERR STATIC FILE INVALID"
and the SA SPT won't get detected and no Modules can be read
 Post subject: Re: "VSC ERR STATIC FILE INVALID"
PostPosted: July 25th, 2024, 13:17
does it spin with the native pcb at all?
PostPosted: July 27th, 2024, 23:53
Yes it spin
PostPosted: July 29th, 2024, 16:04
with or without rom transfer?
PostPosted: July 29th, 2024, 17:31
Is it possible that the bridge is interfering with the data transfer???
Users browsing this forum: No registered users and 38 guests
