 Post subject: Errored: The device is not ready
PostPosted: August 2nd, 2024, 12:50
I recently bought an external hard drive - 4TB - Toshiba Canvio Advance
My problem is when i'm downloading torrent, after downloading well for some time, it says in red "errored: The device is not ready".
I'm using Qbittorent. If i do resume, it will start downloading well again, then after some time, same problem.
The problem is not with the torrent itself.
Initally I thought the drive must be turning off (sleep), so I configured the power management to never turn off the hdd.
CHKDSK revealed no bad sectors and no problems.
Please help me.
 Post subject: Re: Errored: The device is not ready
PostPosted: August 2nd, 2024, 14:20
Run crystaldiskinfo.
PostPosted: August 2nd, 2024, 18:29
I have attached the result of crystaldiskinfo.
All my HDD health was good.
CrystalDiskInfo_20240803022717.txt [20.12 KiB]
Downloaded 426 times
PostPosted: August 3rd, 2024, 6:19
When the error appears, can you listen to see if the drive is spinning?
PostPosted: August 4th, 2024, 20:12
SMR drives are not ideal for torrenting. I wonder if thats the cause
Zero Alpha: zeroalpha.com.au
PostPosted: August 12th, 2024, 11:21
Sorry for late reply.
When the error appears, i can barely hear/feel the drive spinning.
I think it goes to sleep mode.
I need a way to prevent it from going to sleep mode.
PostPosted: August 12th, 2024, 12:09
smr drives are very quite
My firmware database:
PostPosted: August 12th, 2024, 17:49
I used "vovsoft - prevent disk sleep". So the drive was still spinning but the same error appeared.
I don't think the problem is with the specific torrent being downloaded.
But it could be with the Qbittorrent software.
PostPosted: August 14th, 2024, 11:17
Try downloading the drive to another storage. If the file and downloading takes place fine, then it would indicate there is a problem with the Toshiba drive.
Also, try to copy a file to the Toshiba drive, instead of downloading something to it. Does it work? Can you open the copied file successfully on the Toshiba drive?
PostPosted: August 14th, 2024, 22:45
I can copy things to the drive and open them without problem.
I think since its an external drive, there must be some kind of software in it that puts it to sleep after some time.
Users browsing this forum: Majestic-12 [Bot] and 34 guests
