 Post subject: Toshiba Serial Connection Not working
PostPosted: August 12th, 2024, 0:57
Can anybody help me in establishing serial connection through PuTTY. I tried according to hddoracle's toshiba serial connection thread but it doesn't work. Do Anybody has this situation. The Terminal is with a cursor that's all! When I press enter it doesn't enter into dialog mode I.e. >
What am I doing wrong??
BTW I'm connecting through PL2303 and also ch341a bios programmer USB to Serial mode both of them didn't worked. Any solution would be great Thank You!
 Post subject: Re: Toshiba Serial Connection Not working
PostPosted: August 14th, 2024, 5:48
Will anybody help??
PostPosted: August 20th, 2024, 16:09
what baud rate did you use? tosh uses 9600 by default...
PostPosted: September 1st, 2024, 4:14
Tried it but didn't work!
PostPosted: September 2nd, 2024, 3:07
Toshibas are very different btw. you did not specify any model or whats the purpose on connecting that
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 79 guests
