 Post subject: wds240g3g0a-00bjg0 is not detecting!
PostPosted: September 1st, 2024, 3:54
Can anybody help detect my WD 240GB SSD
The SSD is warming but not detected on device manager. Thank You! Please help
 Post subject: Re: wds240g3g0a-00bjg0 is not detecting!
PostPosted: September 1st, 2024, 4:12
PostPosted: September 1st, 2024, 13:41
Measure the voltages at the e-fuse and the inductors surrounding the PMIC.
If they are OK, short the safe mode / ROM mode test points and see whether the controller identifies itself.
PostPosted: September 1st, 2024, 15:03
Can you please elaborate me step by step. By marking on the picture. I don't know which one is which Please. Thank you!
PostPosted: September 1st, 2024, 16:07
I shorted the JP1!. Devmgr shows SanDisk Milpitas and there's no disk on disk management! Showing Disk 3 Unknown Not Initialised.
PostPosted: September 1st, 2024, 17:20
It looks like your SSD has a firmware fault.
As for step-by-step instructions, I have been through this process hundreds of times at this place and others. Also, I've written plenty of tutorials on the subject at HDD Oracle. Please take the time to learn something. After you learn how to drive one car, do you expect that you will need to repeat the process for every other car?
PostPosted: September 1st, 2024, 22:10
So how do I repair this firmware fault.
PostPosted: September 2nd, 2024, 2:00
Any links please and how do I repair this firmware fault Please! Thank you!
PostPosted: November 12th, 2024, 11:36
So this can't be fixed??
