 Post subject: seagate barracuda 8HB ST8000DM004
PostPosted: September 3rd, 2024, 2:20
Is there a workaround for the ROM boot code lock??
Should I read after removing the chip??
 Post subject: Re: seagate barracuda 8HB ST8000DM004
PostPosted: September 3rd, 2024, 2:40
PostPosted: September 3rd, 2024, 4:55
PostPosted: September 3rd, 2024, 13:36
As it says in log " Use programmer for ROM reading" - You can not use PC3K ( for now )
Read ROM with external programmer. Patch ROM in PC3K and write it back again.
I prefer to read/write on board with a pogo clip.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 3rd, 2024, 18:37
- read rom several times and compare them
- make sure you read the full rom, ie not just the half of it with a bad config.
PostPosted: September 3rd, 2024, 21:54
Thank you! so much! :D :)
PostPosted: September 3rd, 2024, 21:55
How can I make the comparison accurate?
PostPosted: September 4th, 2024, 0:34
Make sure you chose the correct chip in your programmer. Read and save several times and compare your dumps.
PC3K HexEdit, WinHex whatever you prefer will do fine. Also check ROM info when you load it in PC3K.
PostPosted: September 4th, 2024, 4:13
i would add TotalCommander as an option, it can do that OOB.
PostPosted: September 5th, 2024, 21:21
You have completed the ROM patch.
However, the data is not visible.
What's the problem?
Upload both terminals and logs.
Everything seems normal on the log.
Just in case, I'm going to post ROM too.
PostPosted: September 6th, 2024, 16:54
Try cloning the drive first then do logical recovery on the clone...
PostPosted: September 8th, 2024, 23:13
pepe wrote:
<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">먼저 드라이브를 복제한 다음 복제본에서 논리적 복구를 수행해 보세요.</font></font>
It looks like this.
The folder with E does not have data even when it is recovered, and the capacity is zero. In this case, is there no other way but to recover RAW?
Is it broken data?
PostPosted: September 9th, 2024, 2:28
E = EFS encrypted, if I remember correctly.
PostPosted: September 9th, 2024, 4:28
Is it correct that the customer encrypted it?
The customer says he didn't encrypt anything, but does this even encrypt himself?
