 Post subject: HD Tune x Seatools different results in test HDD
PostPosted: September 6th, 2024, 15:05
Is it a myth or truth that the best software to test the surface area and bad blocks on a Seagate HDD is Seatools?
I use a Seagate 2.5" 500GB HDD + a Sata to USB 3.0 adapter plugged into the USB 3.0 port on the back of the motherboard. The HD Tune test found a few red blocks, but the Seatools Detailed Generic Test showed the HDD passed the test.
The different results are very strange. Which one is more reliable?
 Post subject: Re: HD Tune x Seatools different results in test HDD
PostPosted: September 6th, 2024, 16:51
do you get the reds at same loc if you test multiple times?
i suspect it is a result of OS interaction with the DUT.
unmount any partitions on that drive and run the test that way
PostPosted: September 6th, 2024, 17:00
I performed two or three tests with HD Tune and the same red block in the same place
Is SeaTools reliable and safe for accurate scans?
PostPosted: September 7th, 2024, 6:02
Yes.
PostPosted: September 7th, 2024, 11:56
Is SeaTools reliable and safe for accurate scans or fake?
PostPosted: September 9th, 2024, 6:03
Yes.
Users browsing this forum: No registered users and 108 guests
