 Post subject: Adding DQS signal support in VNR for ReadRetry -any chances?
PostPosted: September 9th, 2024, 6:17
Hello, some Micron/Intel and Samsung chip are using DQS signal instad WE to set read retry value in registers. Are you familiar with this topic and are there any future plans to introduce such an option? Just add options in which interface (standard WE or DQS) the value should be written to the RR registers, and specify which of the VSP signals is connected to DQS.
When using DQS for RR, the WE signal is high. The command and addressing are performed as with the standard interface with WE. Think about it, Thanks.
ps. I have made a special flip-flop on CPLD that convert WE to DQS, but it would be nice if it worked natively in VNR.
 Post subject: Re: Adding DQS signal support in VNR for ReadRetry -any chan
PostPosted: October 1st, 2024, 12:10
Hello Gregory,
yes, we are aware about this, and there are plans to resolve this issue. I hope that next year we will release the solution.
