 Post subject: Seagate ST1000LM037 No Power Problem
PostPosted: September 13th, 2024, 5:42
I recieved this hdd with no power problem. I replace pcb and original rom with donor pcb. Now hdd detected with no initialisation problem. When scanning with r-studio software all sector bad sector. I think it has translator or partial access problem. Can somebody unlock rom because of i haven't expensive tool like pc 3000 or mrt. I submit rom as attachment.
ROM.rar [270.73 KiB]
Downloaded 163 times
 Post subject: Re: Seagate ST1000LM037 No Power Problem
PostPosted: September 13th, 2024, 6:36
If you don't have an expensive tool like PC3K or MRT I'm not sure unlocking the ROM will do anything for you as you won't have the tool to work with the unlocked ROM.
I have unlocked it with PC3K and attached it anyway, hope it helps.
Rom unlocked.zip [500.65 KiB]
Downloaded 161 times
PostPosted: September 13th, 2024, 6:39
Thanks Sir, I will Try and Update you.
PostPosted: September 13th, 2024, 6:51
hello sir,
hdd is not powering on after write unlocked rom.
PostPosted: September 13th, 2024, 19:19
drive is SED and based on the date it is tied to the MCU, so with foreign PCB it cannot decrypt data correctly. Even if it wasn't the case, DeviceFault is set if started with donor pcb, which results in an error on any read command, which might serve as an explanation of your experiences...
PostPosted: September 13th, 2024, 19:32
If you're just a ROM jockey and head swap mechanic, it's time to put away your tools and look for another job.
Users browsing this forum: Google [Bot] and 59 guests
