 Post subject: surface scan corrupt files in HDD?
PostPosted: September 20th, 2024, 5:25
Can performing Full Surface Scan with Victoria corrupt files saved on the HDD? Is there such a risk?
 Post subject: Re: surface scan corrupt files in HDD?
PostPosted: September 20th, 2024, 15:34
Risk is never zero. Specially when drive has problems. That's common sense, isn't it? Why you ask these things?
PostPosted: September 20th, 2024, 15:35
is hard or easy?
PostPosted: September 20th, 2024, 15:38
Don't be so obtuse.
PostPosted: September 21st, 2024, 11:23
sonicmario wrote:
is hard or easy?
After a quick surface scan I am hard now.
And I feel easy!
sonicmario, a phrase has to have at least a subject.
If you leave out the subject nobody will know what you are talking about!
PostPosted: September 21st, 2024, 17:33
rec wrote:
sonicmario wrote:
is hard or easy?
And I feel easy!
Too much information ..
PostPosted: September 21st, 2024, 17:38
victoria's quickscan is sufficient or not to show whether the hdd is good for archiving and reveal whether SMART has been reset or firmware changed
PostPosted: September 22nd, 2024, 7:14
hdd archiving or and good been not show reveal has changed whether reset quickscan for whether firmware to the victoria's or sufficient SMART is is
PostPosted: September 23rd, 2024, 17:12
sonicmario,
see what you did?
You broke Joep's translator!
If you are not familiar with the English language, this site could help you if you feed it with correct sentences in your mother tongue:
https://www.deepl.com/de/translator
PostPosted: September 25th, 2024, 5:56
I use HDDs for archiving
HDDs 2.5" purchased on AliExpress, do the data recorded on them easily become corrupted if I do not perform a Full Scan Surface with Victoria to find out the true health of the drive? I only performed the QuickScan Surface of Victoria and there were no errors
When I copied the files to the HDD, I then tested them with Winrar and they were intact, but do they easily become corrupted in unused storage or the next time I power them on?
PostPosted: September 29th, 2024, 3:42
Online retailers here in my country do not provide adequate packing for HDDs.
I do not want to bear that risk.
As for shipments from Asia to London (where you pretend to live) I guess it is even worse.
But I guess that refurbished disks are not worth being packaged adequately :)
If your disk is dammaged using Victoria won't make it healthier nor will prevent the disk from " easily become corrupted".
