 Post subject: Seagate ST3802110A - modyfy APP to disable error processig
PostPosted: September 30th, 2024, 12:13
Hi
While back i got this Seagate Barracuda ST3802110A IDE drive. After starting, the heads click for around 4 seconds, then stop and so on. Disk is seen by BIOS and Windows, but I can't do anything with it (it has a RAW partition, which fails to format). SMART shows around 10k reallocated sectors, HDTUNE shows bad sectors in a repeating pattern. From what I've heard this is an issue with error procesing, which could be fixed by editing the APP of the drive. Sadly I couldn't find the required commands for it, so I'll ask here if anybody can guide me on how to disable the error procesing.
 Post subject: Re: Seagate ST3802110A - modyfy APP to disable error process
PostPosted: October 1st, 2024, 2:12
Are you trying to repair it to use again? or do data recovery? If you need data recovery then do you have any professional tools?
Zero Alpha: zeroalpha.com.au
PostPosted: October 1st, 2024, 2:42
I'm trying to repair it. Data is not important, just wanna squeeze that little bit of life it has.
PostPosted: October 1st, 2024, 10:16
Yes, I'm trying to repair it. The data is not needed, just trying to squeeze the little bit of life it has.
PostPosted: October 1st, 2024, 11:16
https://www.phantom.sannata.org/viewtop ... 13#p364013
PostPosted: October 14th, 2024, 11:34
From my understanding, the disable error processing command will be at level C> ? Or am I searching in the wrong place?
PostPosted: October 14th, 2024, 22:46
Its not repairable. Simply replace it
PostPosted: October 15th, 2024, 8:20
After running C,,22 command the drive became undetectable. In terminal I get:
>Interface task reset
1024k x 16 SDRAM
TONKA2 - 1_Disk    M-31   03-22-06 10:53
Head Mask FFFF - Head Mask FFFF - Switch to full int.
              Spin Ready
(P)PATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .0C6
Cert Table loaded
T>
Which probably means I screwed this drive more than it was before. I'm still hoping to atleast make it be detectable instead of a total piece of scrap, so I'll ask if anybody has any ideas.
Users browsing this forum: Bing [Bot] and 299 guests
